Delta Force 29 (knock off) Build
  • ED66677
    • 1300
    nice run Ken!
    my DF copy doesn't have trim tabs, and COG is at 18-19%, Feigao 8XL and K42 carbon prop, speed is pretty much the same as you but amp draw is half of what you have, up to now prop was parallel to keel and I'm planning to lift it up 1 or 2mm to "lighten" the noze.
    if you put your tabs flat they shouldn't create any drag, but moving the COG further in the back should help a lot to reduce amp draw!
    Emmanuel
    • Brod
      • May 2009
      • 196
      Good video,it seemed to be running ok,maybe a touch wet.
      I have the same hull,same colour.
      I will be cutting the wood stringers out completely and using a light mount.It will be lighter than yours.
      2100kv Mega plus a 5000 4S 25c pack.
      Mine will rip on a X442 prop.
      I can imagine your cofg would be well out with the bat. up front.
      My motor will be as far forward as poss. with the bat,behind almost in the middle of the hull.
      If you can lighten yours up,it will be quicker.
      These hulls are strong and well made,the stringers were made for nitro motors and not needed for FE.
      If you can get the shaft/motor aligned perfectly you only need a small plywood tbar jobby
      get rid of those trimtabs,saving weight again..
      Mine last one didnt need turn fins either.
      Brod..
      Slow gets boring fast.
      • Punisher 67
        Ignore list member #67
        • May 2008
        • 1480
        Emmanuel from France
        Are you sure your CG is at only 18%-19% . that sure seems awful low , The boat sure honks good on Video Ken.........LOL
        Necessity is the mother of invention.............
        Youtube Video's http://www.youtube.com/user/Titanis2000
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          I agree Peter mine is set at 28% on a flat pond.
          Douggie
          • Punisher 67
            • May 2008
            • 1480
            Douggie my good friend , Any help here would be appreciated...... . We feel the boat could be faster given the amp draw or is Ken close to the mark
            • ED66677
              • 1300
              OOPS! sorry I measured it a long time ago it is at 190mm witch equals 25% and not 19%, shame! I knew there was 19 somewhere in the number!
              Emmanuel
              • ray schrauwen
                • 9472
                Nice cooling plate. Did you get that esc from ebay or Hi-model?
                Nortavlag Bulc
                • Flying Scotsman
                  • Jun 2007
                  • 5190
                  #23
                  Trim tabs are OK but how do you have them set up.. neutral/positive?? A Prather 225 prop may make this rock and roll and your speeds are very similar to what I run with no melt downs. see my build on this hull . But it all comes down to speed and duration time
                  Douggie
                  • tylerm
                    • Nov 2007
                    • 310
                    #24
                    I find the prather 225 and 230 quite stable props. The ones that made my mono do wheelstands and torque roll were bigger 3 bladers.
                    • Flying Scotsman
                      • Jun 2007
                      • 5190
                      #25
                      Tyler, when I say rock and roll, it is an old fart statement in the vernicular that it may work.
                      Douggie
                      • Doug Smock
                        Moderator
                        • 5272
                        #26
                        Hi Ken, good looking build sir!!
                        IME with 2 degrees of up in the strut that thing should be running loose with the CG at 28% in those conditions in your video. It looks like you have it pinned down pretty good.
                        Are the tabs adjusted down below the bottom of the boat?
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • ksm2001
                          • Jun 2007
                          • 377
                          #27
                          The tabs are mounted flush with the bottom and at 0 degrees, but noticed that with the strut being up 2 degrees I might be fighting the two forces, if that makes sense?
                          The Prather 225 sounds what I'm looking for as long as the himodel can take it, rock and roll would be right
                          I'm glad to hear that the 28% is good, I did have it at 31% as mentioned befor but ran way to wet so moved everything as far back as possible.
                          This is only my second mono as my SV27 was my first but have to say this thing sticks to the water compared to the SV, guess this is why I want to run this hull fast, oh ya and see if I can beat Peter against his Sniper.
                          Thanks
                          Ken
                          DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
                          • line6
                            • Aug 2008
                            • 478
                            #28
                            It does seem a little off to me. it runs well, a little wet but not bad. are your lipos in good shape? also did you play with any timing in the speed control. and if you can please post a pic of where you have the setup now to get 28% cog if you don't mind. the lowest i can get is 29% 4s1p and little over 30% with 4s2p.
                            • ksm2001
                              • Jun 2007
                              • 377
                              #29
                              Lipos are new 2s 4900 polyquest 25c, the timing is set at 0 degrees, the motor mount is built to hold the motor and esc making it a drop in unit. With 2 - 2s packs I get the cg at 28%.
                              • Jeff Wohlt
                                • Jan 2008
                                • 2716
                                #30
                                There is your problem...no timing. Even the AQ ESC for the UL1 has 10 degrees from the factory.
                                7-10 would be good.
                                www.rcraceboat.com
                                [email protected]
