Delta Force 29 (knock off) Build
  • bustitup
    • Aug 2008
    • 3071
    #61
    here you go...you CAN NOT beat this price and they are 30c...large gauge wire and have the propper 5.5 bullets installed..there a no brainer
    • Doug Smock
      Moderator
      • 5272
      #62
      Good advice fellas!!!
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • ED66677
        • 1300
        #63
        or a x445
        Emmanuel
        • Punisher 67
          Ignore list member #67
          • May 2008
          • 1480
          #64
          Hopefully Ken will chime in here , we both run together . he is getting virtually 60 mph on a 4C setup using I believe a Feigao 9XL . That boat just smokes
          Necessity is the mother of invention.............
          Youtube Video's http://www.youtube.com/user/Titanis2000
          • bustitup
            • Aug 2008
            • 3071
            #65
            OMG...you mean you all have actually taught me something in these forums?
            • charlotte515
              • Jul 2009
              • 30
              #66
              Thanks for the replies
              Originally posted by bustitup
              yah like an x442
              Will go to 4s, lot less $$$ required
              • Doug Smock
                Moderator
                • 5272
                #67
                Originally posted by ED66677
                or a x445
                Be careful with that 100 amp esc though. May have to work that prop a bit.
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • charlotte515
                  • Jul 2009
                  • 30
                  #68
                  How would I do that? Again looking for top speed.
                  I think I will get a higher amp esc, are the seakings 160 on Ebay decent?
                  Or would a hydra 120 be a better choice.
                  • FastVee
                    • Aug 2008
                    • 649
                    #69
                    HiModel 200A is good choice if you can waterproof it and add watercooling.
                    Seakings are good, but recently there has ben some shorting issues in 180A model if I remember correctly., -just search himodel and seaking on these forums, lots of info!
                    oh, and I have 29 delta copy, sv27 motor and esc, 4s ,s220 prop gives 40mph.
                    Pate
                    www.youtube.com/rangerpate
                    • ED66677
                      • 1300
                      #70
                      if your not going to race 100A is enough, that's what I have on mine with 8XL and I have tried up to 43.5mm carbon prop without problem, 200A himodel is certainly better, Seaking hummmm... wait and see, there's been a factory recall!!!
                      Emmanuel
                      • ksm2001
                        • Jun 2007
                        • 377
                        #71
                        Hi David, I attached the data of my eagle tree reading from one of my runs last weekend, water conditions where perfect for WOT runs.I didn't gps this run but as Peter said this one close if not 60mph. I run a m445 8xl and a Himodel 200 esc and really advise the higher amp esc if you are planning to buy one anyway if you want max speed, I have my CG set at 28% for smooth water conditions. I don't use trim tabs and removed the turn fins (as Pate runs ) and found it very stable, turning is good at WOT. I'll try posting a video of this run some time today.
                        I noticed you said 5min run time and things are getting hot. First where is your cg set at and strut height? Also 5 min is a long time for 4900's 20c and you might be pushing the Lipos close to the 3v/cell which will cause alot of heat buildup fast. Try some shorter runs and take some temp readings. Not sure what speeds you want to hit but remember the faster you want to go the faster things multiply as in temp, amps, heat.
                        Keep us posted, there are alot of very knowledgeable guys on this forum that can help.
                        Ken
                        DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
                        • ksm2001
                          • Jun 2007
                          • 377
                          #72
                          Here is the link to the video. Enjoy
                          Ken
                          • charlotte515
                            • Jul 2009
                            • 30
                            #73
                            Ken
                            Great video!
                            CG is at 30%, does the strut alignment look ok?
                            As far as speed + 50 would do.
                            I have ordered 4s 5000 30c bats and larger props. I guess next is a larger esc.
                            It is running wet but with the 5s 4900 I can't get the CG any further back, hopefully the 4s battery will help.
                            David
                            • FastVee
                              • Aug 2008
                              • 649
                              #74
                              Nice run Ken!
                              I see that you lost the tabs and fins too -much better!
                              Pate
                              • bustitup
                                • Aug 2008
                                • 3071
                                #75
                                very very nice Ken..when a FE boat runs that stable it makes all your efforts worth while
                                what speed was that?....40+?
