Delta Force 29 (knock off) Build
  • ksm2001
    • Jun 2007
    • 377
    #46
    Jason, I ran 11 test runs in all with 2 sets of batteries, The batteries were warmed up before the runs. In all about 12 min in total just looking over my eagle tree graph times. What esc are you using?
    Ken
    DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
    • line6
      • Aug 2008
      • 478
      #47
      Hydra 120. I guess im asking what was the longest you ran to get the temps
      • ksm2001
        • Jun 2007
        • 377
        #48
        longest run time was 3 min with these temps. Now that Im happy with the setup I'll do some longer runs and can post the temps.
        • Simon.O.
          • Oct 2007
          • 1521
          #49
          [QUOTE=ksm2001;98995]Ok, had a chance to do some test runs yesterday water was almost glass smooth. I removed the trim tabs but had to add 3oz of weight to the back of the transom to keep my cg at 28%. Batteries used were Polyrc 4900 4s1p, 25/50c.
          Prop = x442
          Strut = 2 degrees positive
          Timing = 1 degrees
          Max amps = 120
          Rpm = 30000
          Speed= 42mph
          for your help.
          [/COLOR]
          QUOTE]
          I like the look of this setup.
          I can go 28% Cg and x442
          Strut 2deg positive ?? This is prop end up 2 deg right ??
          With your boat keel on a flat table how high is the center of the drive dog off the table.
          Shaft center line to keel line is the measurement I am after here.
          Thanks for any help you may offer.
          • ksm2001
            • Jun 2007
            • 377
            #50
            Hi Simon, I just checked the measurements here for you and with the hull siting flat on a table, length of strut from end (drive dog end) to against transom is exactly 6cm, the center point measured off the table is exactly 1cm at the drive dog end and 9mm on the transom so it's 1mm positive (up), guess its closer to 1 degree. This gives me the best speed with the least amount of amp draw. on smooth water.
            Ken
            • FastVee
              • Aug 2008
              • 649
              #51
              Ken, have you tested the prather 225 yet? (or have you even ordered it yet)
              I just ordered 8XL and 4/8 himodel and thinking what prop to start with.
              I have the s215,s220 from prather and Octura x440,x637,642 and 645.
              If you have eagle three data on any of these, please post it.
              thanks,
              Pate
              www.youtube.com/rangerpate
              • Punisher 67
                Ignore list member #67
                • May 2008
                • 1480
                #52
                Hello Pate
                I am going to chime in for Ken we both run together , he is on holidays right now and may not respond for a few days but yes he does run a eagletree I am sure he will respond as soon as he gets this ......
                Necessity is the mother of invention.............
                Youtube Video's http://www.youtube.com/user/Titanis2000
                • FastVee
                  • Aug 2008
                  • 649
                  #53
                  Cool, thanks Peter!
                  I just ordered the motor and esc so there is plenty of time to find the info I need.
                  Pate
                  • ksm2001
                    • Jun 2007
                    • 377
                    #54
                    thanks,
                    Pate
                    Hi Guys Just got back form my vacation with the wife and kids from Jasper National Park, included a pic of a nice boat pond called Maligne Lake.
                    I got a chance to post a reply back a couple days back on the 10 gauge wire I used on my ESC, not sure if it really matters so much either but keep them as short as possible if you can.
                    I don't have any Prather props but as for the 642 boat running wet was drawing around 120 amps. But not sure now since the trim tabs are removed but it will be less.
                    As for sealing the esc I use Plasticoat and paint it on, this worked very well for me, I never did sand the fets down but instead used the Arctic Silver Thermal epoxy and this worked very good. But sanding till they are level will work well also.
                    Ken
                    • FastVee
                      • Aug 2008
                      • 649
                      #55
                      Cool , thanks Ken!
                      Nice looking pond there, did you have your delta with you? (I cant see your boat in that pic!)
                      The thermal epoxy costs here 16€(23$) /3ml and that is too much !
                      I also ordered the M445 , that should be good prop
                      Pate
                        • 9488
                        #56
                        Originally posted by tylerm
                        I find the prather 225 and 230 quite stable props. The ones that made my mono do wheelstands and torque roll were bigger 3 bladers.
                        What props make your mono do wheelstands?
                        • charlotte515
                          • Jul 2009
                          • 30
                          #57
                          29" DF knockoff question
                          New guy, need some setup help. 29" DF knockoff question
                          Bought the boat used setup is 9xl, x440, Rhinno 4900 5s 20c, turnigy 100 amp.
                          Plenty of speed but runs too hot the bat is going to die if I keep this setup. I am willing to start from scratch to keep the same speed, estimate in the high 40's with about 5 min runtime.
                          What esc, prop and bat would a Nue 1515 1y require and is this the best way to go?
                          • bustitup
                            • Aug 2008
                            • 3071
                            #58
                            my opinion is that 5s is a little to much for a 9xl which is somewhere near 1800kv and the 1515 1y will be worse at 2200kv as far as heat
                            just go to some good 30c 5000mah 4s batts (turnigy from hobby city) ..then you can run 4s2p and should run high 40's and if you want to do just a few speed runs throw the 5s back in always go for higher c rating
                            • ED66677
                              • 1300
                              #59
                              yep go down to 4S and get a slightly bigger prop!
                              Emmanuel
                              • bustitup
                                • Aug 2008
                                • 3071
                                #60
                                yah like an x442
