Vacu Pickle Hydro
  • Mash13
    • 40
    #31
    hey guys, i'm new to model boats and i've got a stockish supervee 27 right now. I love the look of the hydros in the water, and have been searching for ages for a decent RTR hydro. I've been looking for RTR as I have no idea when it comes to installing the gear like stuffing tubes etc. I cant find any decent rtr hydros that really get me going. I like the vac u pickle Semi-Scale Atlas Van Lines Pickle-Fork Hydroplane, to me thats just amazing. So the wife said "OK then" so i'm going to shoot them an email. So its going to be sorry in advance for the dumb questions, but I cant wait to start this boat! Any tips on hardware etc will be appreciated!
    cheers
    Mike
    • longballlumber
      • 3119
      #32
      No worries Mike,
      There are plenty of people that will get you going in the right direction...
      Mike
      • bustitup
        • Aug 2008
        • 3071
        #33
        what you guys think of the pickle?
        I'm thinking of trading my losi eight t for it...he was asking $350
        it has a feigao 8xl and does 50mph...I never seen a pickle cowl like this one has
        • teach
          • Jun 2008
          • 509
          #34
          That cowl was and nose piece was made by an amazing artist I race against. His work is really second to none. Last time I seen that boat run was it was a rocket!
          • Doug Smock
            Moderator
            • 5264
            #35
            Hard to go wrong at that price.
            Rod does some fantastic work no doubt!! Artist indeed.
            I can't stand him! LOL
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • Jesse J
              Former scale FE racer
              • Aug 2008
              • 7198
              #36
              That said, then I fully condone the trade! Much more fun and glory than some land-bound thrasher. GO FOR IT before its too late.
              J
              "Look good doin' it"
              See the fleet
              • Hydromaniac
                • Oct 2007
                • 816
                #37
                The cowling has been severly modified from the stock unit all done by hand, The best that boat runs on is a Nue 1509 1.5 D 2S2P y 537 prop, she will run very high 60s blinking on 70MPH in oval trim. that boat can be ballistic in the right hands. Thanks for the comments guys it was a fun build.
                www.rockymountainthunderboats.org
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  #38
                  Wonder if he was using that 60 amp AQ ESC with the 8Xl
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • Hydromaniac
                    • Oct 2007
                    • 816
                    #39
                    I thought the same thing.
                    • bustitup
                      • Aug 2008
                      • 3071
                      #40
                      As I did also
                      I have a question for you sir........why did you put the rudder on the left as. ALl others I have seen are on the right like Smock and the Vacu site?
                      • Hydromaniac
                        • Oct 2007
                        • 816
                        #41
                        It really does not make a lot of difference on hydros, they seem to work about the same on either side, what I notice is how it will turn on the corners, With the rudder set behind the turn fin it turns a bit like a sprint car and kind of slides through the turn which for my driving style it allows me to hit the turns a little harder. I also used a less aggresive turn fin which helps with a sliding turn instead of a pivioting style turn.
                        • Jeff Wohlt
                          • Jan 2008
                          • 2716
                          #42
                          My Campbell shovel is on the same side and runs and corners great.
                          www.rcraceboat.com
                          • Diegoboy
                            • Mar 2007
                            • 7245
                            #43
                            What I have come to believe is this...
                            Originally posted by a PM
                            "Most Hydros work better with the rudder on the "outside"... In other words, if you turn right, the rudder should be on the left... I think this helps to plant the inside sponson better... However, I've recently been told that Riggers are just the opposite... they run the rudder on the inside..."
                            and
                            "You see the rudder and turn fin are as far away from eachother as possible. . . so mount the rudder on the left and it will be the farthest point... however if the rudder is on the left and you make a right turn.. . the rudder blade will disrupt the thrust cone and cause cavitation and make the boat go off plane. . . . but with a hydro the body keeps it in the air. . on a rigger there is no body to keep it up so it goes on the right where the rudder does not disupt the thrust cone and thus staying on plane"
                            I believe both are very good info.
                            I said it before, I'm going to do it this time. Maybe a Poll about this topic.
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              #44
                              I agree. BUT...it seems to handle better on my hydro with it on the same side as the fin. No blow out that I know of.
                              One other issue is how the rudder pushes the boat if on the left and how it pulls the hull around when on right. Not sure that makes sense but if on the left you can see how the rudder is driving the rear left side of the boat and possibly raise the right front sponson. When on the right it is helping hold it down and bringing the rear end around. The dynamics are certainly different...just wish I could say what I think
                              www.rcraceboat.com
                              • Darin Jordan
                                • 8332
                                #45
                                ...but if on the left you can see how the rudder is driving the rear left side of the boat and possibly raise the right front sponson.
                                It's actually just the opposite... the rudder on the left actually helps to plant the right sponson in a turn... if the rudder is properly setup.
                                Darin E. Jordan - Renton, WA
