Black Pearl II Hydro - 2020
  • Mike W
    • May 2018
    • 348
    #466
    Originally posted by Shooter
    Just admiring Mike's Q again. That is the cleanest wiring and cleanest cooling line strategy that I've ever seen on any boat. You're a master at your craft!
    Thanks so much Pete! After resisting both hydros and wood builds for years I'm hooked on both and can't get enough. For those unaware I build custom boats exclusively every day so if you've been putting off owning one of these because of the build I'm eager to build one for you!
    The Q is ready for nose and seam reinforcements with 6 oz. cloth, epoxy sealing and primer:
    Otto RC Marine
    • ray schrauwen
      • 9438
      #467
      Mike, that N is a work of art.
      I have a Q, I have a Q!! :) You are way ahead of me though.
      Ray, Good question! Those yellow clamps hold the fore/aft stringers centered between the slots for the spruce sticks. I found sometimes the pcs would drift and cover part of the slots and I'd have to sand the slots larger. You learn a few things after build #52. :)
      Thank you! I'm learning as I go now. I'm just planning out the first gluing of the rear section. I want a n assembly plan so it all goes smoothly and I don't forget anything like having enough weights to keep it all straight.
      It's really odd that I went and searched out some Duck brand shelf paper and the backing is not glue safe like yours. Same brand and same paper as far as I can see but glue sticks to mine so there is a layer of parchment on top.
      The grid lines really do help a lot and it's almost like they were thought of when you designed the hull since the center motor mount section stringers line right up with a pair of grid lines.
      I also pre-bent the outer stringers so I do not have to use very much weight at all to keep them exactly where they need to be. I really don't like leaving any tension in a wood part when that tension doesn't create strength. Heck maybe I'm wrong and talking through my hat?
      Nortavlag Bulc
      • ray schrauwen
        • 9438
        #468
        Originally posted by Mike W
        Who else has a Q? Qv12#106 rigged and ready to bond decks:
        Where does your esc water pickup source? Nice build!!
        Nortavlag Bulc
        • T.S.Davis
          • 6228
          #469
          Doesn't add strength or anything but when I put the motor mount stringers in place I clamp everything to 1-2-3 blocks so it ends up square. Just looks more gooder. I sometimes add mahogany sticks where the motor plate and stringers meet the tub. Depends on the abuse I'm planning to put the boat through.
          Noisy person
          • ray schrauwen
            • 9438
            #470
            Cool, thanks Mr.T.
            You can actually pre-glue the motor mount bulkhead and stringers before you do the whole rear section. It makes it more simple to do as it just drops in.
            Nortavlag Bulc
            • Mike W
              • May 2018
              • 348
              #471
              Just a dual-pickup rudder.
              Otto RC Marine
              • T.S.Davis
                • 6228
                #472
                That's how I do it too. One less thing to align.
                Noisy person
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2520
                  #473
                  Wow. I never thought of doing that! Good call!!
                  • jaike5
                    • Dec 2011
                    • 561
                    #474
                    Hi Pete,
                    Any movement on the Xcat plans
                    Happy New year, Jay.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      #475
                      Stagnant. Little free time these days.
                      • jaike5
                        • Dec 2011
                        • 561
                        #476
                        Ugh!! I get it tho !! I'm 15 year's ahead of you, my kids are 20/30 now.
                        Cheers, Jay,
                        • ray schrauwen
                          • 9438
                          #477
                          I have the rear all tacked up well. The front I'm trying to understand tilting the boat forward. I get that the formers all need to be flat however I don't know how high to raise the rear? It seems that is variable.
                          Nortavlag Bulc
                          • T.S.Davis
                            • 6228
                            #478
                            I get about an hour a day. This scale is killing me though.
                            Noisy person
                            • Shooter
                              Team Mojo
                              • Jun 2009
                              • 2520
                              #479
                              Hi Ray. I could give you the dimension the rear has to be raised. I'm planning on designing a jig for that eventually. I think I had a picture in a previous post.
                              • ray schrauwen
                                • 9438
                                #480
                                I think mine was about 37mm high. I glued it up yesterday and it's now upside down to get the little bits glued in. Then comes the sticks etc...
                                I don't have nice clamps to do the bottom bits so I'll improvise. So far so good. It's a really nice kit to build.
                                Nortavlag Bulc
