you can get a long section of extruded aluminum square from HomeDepot or Lowes. Use a good sanding block to sand the surface flat now you have a long sanding block.
I would agree with Terry on the sanding of the lasered end grain. The laser cutting process seems to "seal" off the end grain of the ply. Without sanding you won't get as good penetration with a glued joint. A good glue joint creates a mechanical bond between the two substrates and your glue. That's why G10 has a tendency to delaminate at the glue joint. The glue can't penetrate into a fully cured substrate (g10). Just my $.02, mileage may vary.
Nortavlag Bulc
I remember Pag's daughter looking at one of my boats that had a super nice paint job and saying how pretty it was. Mike tells her "The pretty ones don't go fast, honey".
