Black Pearl II Hydro - 2020
  • RandyatBBY
    • Sep 2007
    • 3915
    #451
    Randy it looks like you screwed the transom down to the build board.
    Yup
    edit; I was thinking about the real reason for the screw. I use to locate the hull to the building board. I remove the hull from the building board several times this makes sure it is allways in the same spot when I put it back on.
    Randy
    BBY Racing
    • T.S.Davis
      • 6220
      #452
      Originally posted by TRUCKPULL
      Terry
      Do you mean like this?
      Larry
      Yes but something stiffer. I always have random pieces of crap laying around my shop to use. I'm like a junk collector. The struggle is real.
      Noisy person
      • TRUCKPULL
        • 2969
        #453
        My wife calls me a Pack Rat.
        Larry
        • RandyatBBY
          • Sep 2007
          • 3915
          #454
          Larry
          Mine too, but she allways will come to me for help with her project. I guess it is on a everything in my life scale not just RC boats. I built a green huse with her this fall.
          Randy
          BBY Racing
          • RandyatBBY
            • Sep 2007
            • 3915
            #455
            any way mote pictures of my BP PLTD. My change to the sponson.
            I think this will help hold the boat to the water better.
            I am going to have one long opening and only one hatch.
            Randy
            BBY Racing
            • RandyatBBY
              • Sep 2007
              • 3915
              #456
              other skin on the BP
              Randy
              BBY Racing
              • RandyatBBY
                • Sep 2007
                • 3915
                #457
                I got the last deck and nose pieces done, now a little filler and ready to install hardware. I will not be bugging you guys for a while I have a Q sport to build for a friend and two 1/8 scales all wood except the deck and cowl.
                Randy
                BBY Racing
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2558
                  #458
                  Wow, you guys have been busy! Family has been sick, so I took a bit of a break from boats. That's a good idea with the flat stock. I've used it for the deck before, but never the skis. Dang it, Eric! What happened???? Randy, those mods look cool! I like the steep recovery pad. She should plane real easy. I'm interested to see how it runs like that. Oh, and Larry...you ARE a pack rat.
                  • Mike W
                    • May 2018
                    • 348
                    #459
                    I went with the extra-short hatch on the N2. Worked out well with the hardware brackets bonded into the hull and no screws through hull. Doing the same on the Q right now. It should be finished in a couple weeks.
                    Otto RC Marine
                    • eric113
                      • Sep 2011
                      • 323
                      #460
                      Looks great! Cool concept on the brackets.
                      • Mike W
                        • May 2018
                        • 348
                        #461
                        Who else has a Q? Qv12#106 rigged and ready to bond decks:
                        Otto RC Marine
                        • ray schrauwen
                          • 9472
                          #462
                          A Hobbywing motor, neet.
                          Nortavlag Bulc
                          • ray schrauwen
                            • 9472
                            #463
                            Originally posted by Shooter
                            I started my Q. Almost a total fail. I realized the build board was warped while positioning the frame. Eeek!! I managed to transfer everything over to a piece of granite with paper, centerline, and wax paper. Ran some new glue over the joints. Without the gridlines there is no 90deg reference for the transom. I ended up drawing a perpendicular line for reference.
                            What is the purpose of the tiny yellow clamps on the motor mount bulkhead? No weight on top while glue dries?Pearl rear bulkheads.jpg
                            Nortavlag Bulc
                            • Shooter
                              Team Mojo
                              • Jun 2009
                              • 2558
                              #464
                              Mike, that N is a work of art.
                              I have a Q, I have a Q!! :) You are way ahead of me though.
                              Ray, Good question! Those yellow clamps hold the fore/aft stringers centered between the slots for the spruce sticks. I found sometimes the pcs would drift and cover part of the slots and I'd have to sand the slots larger. You learn a few things after build #52. :)
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2558
                                #465
                                Just admiring Mike's Q again. That is the cleanest wiring and cleanest cooling line strategy that I've ever seen on any boat. You're a master at your craft!
