Black Pearl II Hydro - 2020
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    #406
    In another life, I'll add toy tabs in these locations to make it easier to build.
    • Shooter
      Team Mojo
      • Jun 2009
      • 2558
      #407
      Here's another shot of the front frame position with the stand-offs on the back. Maybe we could cut out a jig for this if there is extra room on the sheet? It could have a flat side and another side that has the angle of the AOA on the sponsons and could slide underneath the frame?
      • ray schrauwen
        • 9471
        #408
        I appreciate all these insights.
        When you say to sand the burn marks with no lower than 220 grit, do you mean all the slots or the slots and some of the part faces?
        Nortavlag Bulc
        • Shooter
          Team Mojo
          • Jun 2009
          • 2558
          #409
          Hi Ray,
          Only the faces, not the edges. It is typically only on the back face where the smoke from the laser is exhausted. Lately, I've been keeping all the parts in the sheet, laying the sheet onto a flat surface, then hitting it with a palm sander. That way I don't round off any of the edges. It makes the build a lot cleaner looking without all those nasty burn marks, otherwise, they will just be sealed in for life!
          • ray schrauwen
            • 9471
            #410
            O.k. that's a great idea. I thought the slots where the pieces fit together also need some sanding because of the burning?
            Nortavlag Bulc
            • Shooter
              Team Mojo
              • Jun 2009
              • 2558
              #411
              It seems epoxy would definitely adhere better to "non-burned" surfaces, but I've never had a problem not sanding the edges. The joints are heavily reinforced in later steps when the glass strips are layed in. The framing is mostly just to tack things together, although I've found frames to still be very strong with West Systems.
              • ray schrauwen
                • 9471
                #412
                Wow. Here I was in the past trying to clean the burn marks out of the slots, lol... I am learning a lot from you Pete.
                Nortavlag Bulc
                • T.S.Davis
                  • 6220
                  #413
                  I sand every slot. Not crystal clean or anything. Just some. When I seal I use thinned epoxy. My thinking is that it can soak in to the joint a bit in the process. I wipe every flat surface after my thinned mixture has cured a bit but those joints I let sponge.
                  The trick part about sanding slots is that you have to keep washing your hands. You will get soot on them and it will make the wood surfaces look horrible. If you want to eventually have a wood finish, wash yer hands constantly.
                  Latest pic of my 10.8 attached.
                  Noisy person
                  • Ryanj
                    • May 2020
                    • 133
                    #414
                    I have the V12 version and just a great hydro man. Have you made any new changes or improvements since the version 12.
                    • T.S.Davis
                      • 6220
                      #415
                      None that I know of......despite my whining.
                      Noisy person
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2558
                        #416
                        Maybe you are learning how do things 'wrong' from me, Ray!
                        Terry, that is nuts, as usual. I think I asked what it eats last time.
                        Ryan, I love the green and white scheme.
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2558
                          #417
                          I'm a little behind you Terry. Getting ready to install the bottom on the Q. Also, started the framework for the Q cowl. These boats are a labor of love, for sure.
                          • Ryanj
                            • May 2020
                            • 133
                            #418
                            alright....Mid 2022 race season the boat raced well for my club , so 2023 season is coming and Planning ahead.
                            • Ryanj
                              • May 2020
                              • 133
                              #419
                              Thank you on the color scheme as it came out well. 2nd place to end the race season in my club. So hats off good competitive boat in my club. Looking forward to 2023.
                              • ray schrauwen
                                • 9471
                                #420
                                [ATTACH=CONFIG]176067[/ATTACH]
                                Nice, looks angry.
                                Yeah, I notice that mess too. I am almost ready to get started. Something was off and it appears it was my square, bent. I just borrowed a proper one so now I can set up the build board and then pull parts to sand.
                                Since I cold not get a nice aluminum (long) sanding block I had to make some out of oak. Those Great Planes sanding blocks Pete shows are a thing of the past. Dubro has taken over and doesn't make the long one.
                                Nortavlag Bulc
