ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • ray schrauwen
    • 9438
    #361
    Lake Superior, wholly cow!
    • sammyha
      • Jul 2018
      • 1038
      #362
      It's a rare day you can run an RC outrigger on Lake Superior...
      • DanBurnmann
        • Apr 2019
        • 1
        #363
        I made such a boat and used three packs of glue. The glue spread all over the chair and now it's all on the carpet. Has anyone come across this? How to clean everything from glue?
        Boat lover since 2012. Fishing as hobby since 2008. Work as boat and yacht cleaning pro at UCM Upholstery cleaning.
        • ray schrauwen
          • 9438
          #364
          Is it mixed and dried or is it just unmixed?
          • Peter A
            • Sep 2012
            • 1492
            #365
            I think this guy Danburnmann could be a fake profile. Notice he cleans upholstery and just joined yesterday! Either that or an idiot.
            • cybercrxt
              • 2909
              #366
              With that boat, you have to just open it up full throttle, and steer. If that was a 42mph run, you have a good 60-70mph setup, because I never heard you actually wind the motor. I have had the 31" RSX in the 70mph range, and it didn't care, so you have nothing to worry about. I always shake when I put an R&D design in the water for the first time. You get over it real quick tho! Congrats on the nice build, I think you will be amazed once spring comes, and you can set the strut, and really get it up on top of the water. Riggers do not like low speed for turning, it will lock in once you get it up on top of the water! Mike
              • sammyha
                • Jul 2018
                • 1038
                #367
                Thanks Mike, that was my first drive with a rigger. Just wanted to maiden it, and not hit floating ice or run it up on the ice. It was a bit nerve racking with the situation and being a maiden run.
                I need feedback like yours and setup tips for sure. So thanks for the help.
                Here's my bench tune. Leopard motor 4092/1390kv, ABC prop 2118(b,s,p), 40 size Mojo Racing turn fin (front of turn fin even with back of sponson ride pad), CG on 6s balances 1/2" behind back of turn fin(8s should be a little closer to back of turn fin), bottom of strut even with bottom of rear pads, prop shaft/strut neutral or parallel with bottom of tub.
                The only other adjustment I can think of is, I have almost 1/32" toe-in on the right sponson to offset for prop walk because my strut is mounted on center and not shimmed to the right.
                I did run it off camera to 55mph. And noticed a slight lifting and dipping of the front sponsons. Possibly running slightly wet? Do I need some positive strut angle?
                Or, as Mike said, give it more throttle and she'll settle?
                • sammyha
                  • Jul 2018
                  • 1038
                  #368
                  What an absolutely fine looking build! I would like to put the pics up on the website! I look forward to seeing it running! Mike
                  If you're still interested Mike, here's a couple more pictures. What I call amateur studio shots...
                  • Steven Vaccaro
                    • 8724
                    #369
                    Id love to have permision to use these for ose products page. Let me know if you mind?
                    Steven Vaccaro
                    • sammyha
                      • Jul 2018
                      • 1038
                      #370
                      For sure you can use them Steven. I don't mind at all...
                      • Steven Vaccaro
                        • 8724
                        #371
                        Thanks!!
                        Steven Vaccaro
                        • Steven Vaccaro
                          • 8724
                          #372
                          Thanks!! I updated the product, it looks much better now.
                          https://www.offshoreelectrics.com/pr...prod=ml-rsx380
                          Steven Vaccaro
                          • sammyha
                            • Jul 2018
                            • 1038
                            #373
                            Nice! That's what we appreciate about you. You make it happen, now!
                            • Steven Vaccaro
                              • 8724
                              #374
                              The secret is, if i dont do it now and while its on my mind, I will forget about it, like it never happened.
                              Steven Vaccaro
                              • sammyha
                                • Jul 2018
                                • 1038
                                #375
                                If I were to be totally honest about it, I've not been running my rc boats because I've been golfing... [emoji2958]
                                And working overtime. And putting up a new riding arena rail and gates for Wendy. [emoji106]
                                Anyway, I did get out and run the RSX380 today. I prepped a slightly smaller prop for it. Went to a ABC 2018, was running a ABC 2118. And set some positive angle in the strut. The bottom of the strut is flush with the bottom of the rear shoes as before.
                                Here's a link to a video of me checking it out, taking out some of the left trim I was running(less propwalk), and opening it up a bit running laps. I'm going to full throttle here on the straights, but not going quite to full speed. It's over steering slightly in the corners, I had my batteries set all the way back.
                                Just figuring out what it likes, trying different things...
