ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • sammyha
    • Jul 2018
    • 1036
    #31
    Would I have overheating issues with the TP 4070 1650kv on 6s? And would a 220 amp Swordfish esc handle that?
    • Raydee
      • May 2007
      • 1603
      #32
      I wish I could tell you, I haven't run either to know. I would say you will be right around 35k rpm so as long as you don't over prop I think your setup would be fine.
      Team Liquid Dash
      • sammyha
        • Jul 2018
        • 1036
        #33
        Here's a setup on 6s with the TP Power 4070, 1650kv...
        • Raydee
          • May 2007
          • 1603
          #34
          What are you figuring your voltage per cell under load at?
          Team Liquid Dash
          • sammyha
            • Jul 2018
            • 1036
            #35
            I don't know how to figure that.
            • jim82
              • Jan 2013
              • 1358
              #36
              I have a Tp 4070 1650kv used 2-3 short runs I would sell if interested
              • Raydee
                • May 2007
                • 1603
                #37
                So what are you using to figure out your total RPM? Normally I take the pack voltage under load (I am usually at about 3.5 volts per cell) times 6s= 21 volts x 1650 = 34,650rpm
                Team Liquid Dash
                • sammyha
                  • Jul 2018
                  • 1036
                  #38
                  Oh, duh me...Using the OSE calculator I can figure theoretical results. I don't know how 6s would do tho. As far as overheating goes.
                  I think I can relate this to helis. The big 6s birds fly well due to size, but the electronics are being pushed too hard. Go with 12s and no worries.
                  I think 8s for the SAW running would be best.
                  • sammyha
                    • Jul 2018
                    • 1036
                    #39
                    Those are loaded rpm's from the OSE calculator in my figuring.
                    • Raydee
                      • May 2007
                      • 1603
                      #40
                      Because I don't race and I am not restricted to any rules I always say the higher the voltage you can run the better off you will be to keep the amps down. If two 5s packs fit this boat I may end up running 10s in it.
                      Team Liquid Dash
                      • sammyha
                        • Jul 2018
                        • 1036
                        #41
                        Thanks. I'll keep that in mind, but I'm leaning towards an 8s setup.
                        • sammyha
                          • Jul 2018
                          • 1036
                          #42
                          Ok. I'm getting it now. That's not the first time I've heard that. Low amps, high voltage.
                          I'm going with an 8s system.
                          The OSE calculator gives the numbers which is a good start. Then there's the real world. I need 8s to push this rigger over 90mph I'm guessing, without overheating issues...
                          Probably even 85mph would be expecting too much from a 6s system.
                          • sammyha
                            • Jul 2018
                            • 1036
                            #43
                            Haha! I kind of muddied up my own thread. But, this does show the newcomers struggle with electronics decisions I suppose...
                            Ok. So a TP Power 4060, 1350kv, 4y motor. On 8s lipos. With a Swordfish X+ 200 amp esc. And an ABC 2216-10-50 CLL prop.
                            That should give me a 102mph potential top end with a 3.52 total pitch prop. Very reasonable.
                            And I could maiden the boat on 6s, same prop at a sensible 76mph top end...
                            • sammyha
                              • Jul 2018
                              • 1036
                              #44
                              After curing for a day, I pulled the weights and tape off. Success! The top seams are tight...
                              • sammyha
                                • Jul 2018
                                • 1036
                                #45
                                Something I noticed with epoxy. It definitely strengthens(cures) more overnight, to the point where it maintains shape as far as flatness goes.
                                Yesterday I picked it up after the epoxy had set, to give it a once over. It had a slight twist. So, very important to leave it weighted for 24 hours.
                                Slight twist is gone now, very straight and flat. It feels more rigid now too.
