I wish I could tell you, I haven't run either to know. I would say you will be right around 35k rpm so as long as you don't over prop I think your setup would be fine.
So what are you using to figure out your total RPM? Normally I take the pack voltage under load (I am usually at about 3.5 volts per cell) times 6s= 21 volts x 1650 = 34,650rpm
Because I don't race and I am not restricted to any rules I always say the higher the voltage you can run the better off you will be to keep the amps down. If two 5s packs fit this boat I may end up running 10s in it.
Ok. I'm getting it now. That's not the first time I've heard that. Low amps, high voltage.
I'm going with an 8s system.
The OSE calculator gives the numbers which is a good start. Then there's the real world. I need 8s to push this rigger over 90mph I'm guessing, without overheating issues...
Probably even 85mph would be expecting too much from a 6s system.
