I ordered some 1" polyethylene sheets. It's the same foam used to make pool noodles. I do have black noodles, but it's just an awkward shape. I figured I could use more area in a neater way with the sheet. My AUW should be just under 6kg (~13lb). What you see is 7.38kg worth of flotation, but that's only 3" thick. I can still fit another two narrower layers into the V.
I also got the ESC's finished. I just have to figure out how to cover it up. Maybe some heat shrink around the bullet with a dab of epoxy around the solder joint.
