HPR 010 Mono: Very Slow Build
  • boredom.is.me
    • Jun 2009
    • 595
    #136
    I only gave enough to make sure everything was operating properly.
    The "blade" antenna actually isn't that big. The difference between the blade and the shark fin is the orientation.
    I'm just using SketchUp.
    Nothing like wires to kill the prettiness. The caps on the esc wires are obnoxious too. Why could they have placed the closer to the ESC? I still have to figure out how I'm going to balance the two sides. With these ESCs, I may have to peel away the shrink around the caps and solder my cap bank wires directly to the ESC cap bank.
    I can shorten the ESC>motor wires a lot, but I'm not sure how much that will do as far as looks is concerned. I may design a carbon plate for each side to cover it all.
    It will run as seen here.
      • 7673
      #137
      Well you have done well for a so called 'slow build', my last one took me all of a year! LOL.
      Looks good, most of us just make some sort of cover for the wiring. It is all one can do.
      • golfito
        • Sep 2011
        • 296
        #138
        I enjoy your photos. I am amazed at the quality of the work he is showing.
        Regards!
        Saludos!
        • boredom.is.me
          • Jun 2009
          • 595
          #139
          I'm probably going to reduce the motor to esc wires a bit before I actually run it. Right now, I'm planning out the cover in case the reduced wiring doesn't suffice.
          Turns out, my stash of carbon rods is missing... gotta love moving. I have to make a trip to the LHS for some. That's what I'll use for the hatch pins. (I know, it was against recommendation, but if the cause was determined above, there shouldn't be any issue.)
          I also have to clean up the hatch cutout on the hull. I purchased a cheap band file sander to remove some welds when I was bringing my car back to life. That should work pretty good for this since it has a long flat sanding surface.
          I will ape over the holes I made for the lights until the boat gets painted. The lights setup itself is kinda of annoying me. Without "permanently" gluing them, there is no real way to secure the bezels. Also the LEDs I used are straw hats. I feared that standard LED's would be too tall. What interesting is that the straw hats aren't actually 5mm LEDs. They are 4.7-4.8mm, if not smaller. I shoved a 5mm into the buckets and it stayed in snug as I would have wanted. The straw hats on the other hand, just fall out, even with some heatshrink wrapped around them. I'll trade out all of the straw hats for standard 5mm LEDs.
          The chrome on the motors irritate me. I hate chrome with a passion. The thought of masking off the endbells and running the motors against 1000 or 2500 grit sandpaper came to mind.
          There seems to be a weird bug that prevents images from url's through the image tool. I manually used [img][/img] to post that pic.
          • boredom.is.me
            • Jun 2009
            • 595
            #140
            Slight update: I have not ran the boat yet. I did however redesign the light buckets. They are now a two piece clamping design that will allow me to easily mount the led separately, then attach that to the final external bezel. Aside from that, I'll most likely be doing all of the body work before it hits the water.
            • boredom.is.me
              • Jun 2009
              • 595
              #141
              I didn't sand the entire rear void out. The front on the other hand truly was a void. There was a pretty impressive air pocket under the gel coat.
              sent from under your bed
              • boredom.is.me
                • Jun 2009
                • 595
                #142
                Letting this sit for a while before I start sanding. I also trimmed the hatch cut out. Now it's all nice and pretty....And dusty.
                Now I'm in full "how to paint it" mode. Something simple and symmetrical is all I want. The bottom will be white for sure. My windshield and "turbine hatch" decals are black carbon. The lettering for everything else is white or silver. (I have both colors.) I'm all for throwing red in the mix as long as it doesn't make it look ricey.
                  • 7673
                  #143
                  Umm... wow! So was that JUST gelcoat on the surface?
                  Just starting my HPR now.
                  Shawn
                  • boredom.is.me
                    • Jun 2009
                    • 595
                    #144
                    Yep. I noticed it when I pressed on the area and the edge around where I sanded completely lifted. So I started scraping away with a razor and that's what I got.
                    One thing I didn't see coming is the white haze you see on the battery tray. The Gorilla Super Glue I used to try to stick some of the pool noodles together gassed and left a lot of that stuff everywhere. What surprising is that I feared that would happened and left it to gas off for over 24 hours before I actually put the noodles in the hull. So after all of the body work, I have to give the interior a good scrub down.
                    Shawn, which hull did you get?
                      • 7673
                      #145
                      I have a 115 bulletproof. I'll do a thread when I'm further along. I have a bad habit of getting most of it done and then the last couple things take me all year.
                      I know, my dedication sucks.
                      • boredom.is.me
                        • Jun 2009
                        • 595
                        #146
                        Sounds like you need to just send it to me. :)
                        • boredom.is.me
                          • Jun 2009
                          • 595
                          #147
                          • TheShaddix
                            • Sep 2013
                            • 759
                            #148
                            Can't believe that an hpr boat would have such huge air voids. I remember when I started sanding my mhz cat I found some small air pockets and was not happy about that. Always thought hpr hulls were superior in that regard. I totally understand some air bubbles are unavoidable. But after seeing this I don't know why they are still so reluctant to use vacuum bagging. They should just charge more, people will still buy their hulls, but they should not make crap like that with have huge voids in them... Without a bag pressing constantly onto the fabric while curing there is just no way to know how it'll end up.
                            Also, are you going to reinforce those hatch pins with something?
                            • boredom.is.me
                              • Jun 2009
                              • 595
                              #149
                              Ya, it's not like it's a $200 hull. I think I paid around $480 before shipping. That's not much considering that this is actually one of the smaller hulls. Unlike MHZ and some of the others, HPR is a one man operation, but that shouldn't change anything. The big blotches are already irritating. Now imagine if I spent $1000 on a hull alone.
                              Yes, I'll be putting a 1.5mm carbon plate over the pins.
                              • boredom.is.me
                                • Jun 2009
                                • 595
                                #150
                                Didn't finish the last post...
                                I plan on smoothing the edge of the hatch with sand paper, then applying a thin strip of epoxy around the edge. About 8mm would do. The purpose would be to provide a smooth surface for the seal to adhere to...wait did he just say put the seal on the hatch itself? Yes I did.
