8255 Build
  • ray schrauwen
    • 9471
    #121
    Sneaky EDIT you!
    Ray, the Redwing whip that had wings and almost no transom was 1/32 ply. With the exception of its ride pads. Then I doubled up at the shaft penetration. At least I think I did. That was 2009 or so.
    Nortavlag Bulc
    • T.S.Davis
      • 6220
      #122
      HAHA Ray, did you ever pick that one up? It's creepy light. At the close of our practice season I put a 1527/.5y in it. Fastest thing I have ever driven. One stuff and I'll be calling a diver though. Not a real setup but the grin factor was high.
      I'll take a pic later but after sanding the poly foam down on that curvature it looks pretty good. I'll have to glass it but it doesn't look as horrible as I had anticipated. I'll show how I backed the foam too. Pretty simple.
      Noisy person
      • T.S.Davis
        • 6220
        #123
        Okay first pic is from the inside looking forward. I basically closed it off with ply. Then poured foam on the outside. Cured then shaped.
        Second pic is just from the outside after some sanding.
        Noisy person
        • longballlumber
          • 3132
          #124
          That doesn't look very scale... HA HA HA!
          Later,
          Ball
          • T.S.Davis
            • 6220
            #125
            Epoxy and two layers of what ever scrap I found in my shop. Think it's 1.5oz S glass.
            Noisy person
            • T.S.Davis
              • 6220
              #126
              Wiener. Close enough.
              Noisy person
              • flraptor07
                • Aug 2013
                • 2451
                #127
                I'm the last one to tell you how to do something and it looks awsome. While you were there I think I might have incorperated a air brake in the nose like on the ML boats. You could always fill it in if it wasn't needed.
                • T.S.Davis
                  • 6220
                  #128
                  I just can't do it.
                  Building around a design flaw just doesn't set well with me. I'll keeping massaging the setup until it works without an air dam.
                  I don't like adding 13oz of weight to my Stealth either. I'll be fixing that bugger before I paint it too.
                  Noisy person
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #129
                    I just can't do it.
                    Cool, I was more or less asking, you deffinetly have way more experiance with rc boats than I do. That's basicly the answer I was looking for. Thanx
                    • ray schrauwen
                      • 9471
                      #130
                      Your PTSS? for LSH? holly crap, 13 oz's! I added 3 to front of port sponson and it doesn't sponson walk anymore. Of course I'm carrying heavy 7.6AH on board too and an esc like an anchor... We'll see with soft water. I first have to find my leak. Taking my PTSS to the GF's place on the weekend since she has a tub to test in...
                      Nortavlag Bulc
                      • T.S.Davis
                        • 6220
                        #131
                        Stupid ain't it Ray?
                        I only carry 4400 mah though so we're doing the same thing. You're extra 3200mah and chunk o' speedo might weigh another 10oz.
                        Noisy person
                        • T.S.Davis
                          • 6220
                          #132
                          On the air dam thing.......
                          That seems to be an ML trademark. Not sure why he does that. If the boats are flighty, change the geometry a bit. That's just me I guess.
                          Noisy person
                          • ray schrauwen
                            • 9471
                            #133
                            Yep, pretty much the same. I can get away with cheap packs that weigh a ton but, your lead is even less $$$, lol...
                            I'm switching to the Hacker packs I bought from Jason so, I might need to add weight or just work on it more like yourself. PM me all your hard work and secrets
                            Nortavlag Bulc
                            • T.S.Davis
                              • 6220
                              #134
                              haha I didn't say I had it figured completely out. We have a bunch of these in MI. They all have a hair trigger. You're right at the ragged edge and........................................ then you take flight. weeeeeeee It's why your heavy packs work.
                              After I figure it out I'll tell you exactly what to do. Want me to drive it for ya too?
                              Noisy person
                              • T.S.Davis
                                • 6220
                                #135
                                Plans showed up yesterday. woohoo
                                Noisy person
