New P Sport Hydro 2015!
  • T.S.Davis
    • 6220
    #481
    Pete, do you clamp, heat, then just push to the curve?
    The glue laminating the ply together should get soft with heat. Just never thought of it.
    Noisy person
    • Shooter
      Team Mojo
      • Jun 2009
      • 2558
      #482
      I just put the heat gun in the vice, facing upwards. It's not an exact science. I don't clamp anything. I just hold the ply above the heat and bend to taste. Only takes a few minutes/iterations. After burning my fingers off two or three times I usually put on a pair of leather gloves.
      The real advantage is that it doesn't stress/warp the frame when you tack it on.
      • HydroMike
        • Oct 2011
        • 334
        #483
        what are u getting price wise for the kits
        • Shooter
          Team Mojo
          • Jun 2009
          • 2558
          #484
          More progress!! Only (5)days until the club race!!!
          • Shooter
            Team Mojo
            • Jun 2009
            • 2558
            #485
            Only (2) more days left!! Primer tonight if the weather holds up.
            • rightturnonly
              • Jan 2009
              • 143
              #486
              Looking good as usual....weather hmmm..it's 86 here today..still pool time down here...
              JOHN A. GROSS
              MILLBROOK, AL
              Crickety Crack Racing Team
              • bozo586
                • Aug 2009
                • 344
                #487
                pete-what kind of tape is that? it must be better than the paint tape i use!
                • T.S.Davis
                  • 6220
                  #488
                  Just seal it Pete. No need to paint before the weekend. It's just exhibition.
                  John, I've had good luck with Gator Tape. Seems to stick just a tic better. Looks like that might be what Pete uses there. They make it in cloth or vinyl.
                  Noisy person
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2558
                    #489
                    To Jr:
                    To Sr: 3M automotive finishing tape.
                    To Terry: lol. Hung it from the swing set in our backyard and painted it last night in the DARK! It was also misting a little bit. Doesn't look half bad for the conditions!
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2558
                      #490
                      Based on performance last Saturday and during our last club race, the changes will be implemented.
                      V5.7
                      -Flat sponson ride pads
                      -Increased recovery pad angle of attack (no drop nose)
                      I will start laser cutting wood in November.
                      • TRUCKPULL
                        • 2969
                        #491
                        Thank You
                        Pete
                        Keep me posted.
                        Larry
                        • ray schrauwen
                          • 9471
                          #492
                          Me too.
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2558
                            #493
                            Ray - did you want one of these? I don't have you on the list.
                            • Speed810
                              • Jul 2014
                              • 288
                              #494
                              Pete....
                              With the mods you made in Ver 5.7 did you just modify the ride pad on the inside sponson and leave the 3 degree dihedral on the outside sponson?
                              Also did you switch up the power package on the latest build?
                              Mike
                              • ray schrauwen
                                • 9471
                                #495
                                I'll send you a pm. I didn't know there was a list.
