New P Sport Hydro 2015!
  • T.S.Davis
    • 6221
    #181
    Haha. Just remembered this too. Always make sure you zero out your machine before running a command set. Unless you find watching a 3000 pound machine jumping off the floor amusing . Been there done that.
    Noisy person
    • Shooter
      Team Mojo
      • Jun 2009
      • 2558
      #182
      PDF to DXF can be tricky. PDFs are just raster images while DXF is vector. I went thru this process when making the skin kits. What are you trying to convert, Darryl??
      • darryl whitman
        • Sep 2012
        • 535
        #183
        just hand scale drawing of parts for boats and airplanes. a guy here in Iowa city ,Iowa, can cut out pcs , but he needs my pdf drawing converted to dxf.
        • T.S.Davis
          • 6221
          #184
          I've converted pdf to dwg. Once you have a dwg it's no biggy to export to dxf. The trouble is that if the pdf is actually a scan it becomes a million little segments in Autocad. A simple curve might actually become 60 bits. Then the machine would try to cut that curve in 60 little movements. Ack.
          If you know someone with autocad, see if they'll duplicate your sketch. Export to dxf is a breeze.
          Noisy person
          • flraptor07
            • Aug 2013
            • 2451
            #185
            We're gonna have one of these in Florida now, Pete just sent mine out yesterday! Can't wait to get started on it! Thanx Pete
            • Shooter
              Team Mojo
              • Jun 2009
              • 2558
              #186
              Best way I've found is using a software with tracing capability (Adobe Illustrator, Corel, etc). Set the threshold so you limit the segments (what Terry was talking about). Then just export as DXF. Simpler said than done.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2558
                #187
                I cut a boat for flraptor the other night. Laser was running well (that's not always the case!!)
                Also, started the stuffing tube install on the first boat and began machining the one piece strut/rudder for both boats.
                • flraptor07
                  • Aug 2013
                  • 2451
                  #188
                  Got my kit today! Very impressed with the kit and packing, I'll get started when I get back from Colorado week after next. Pete, if you're doing a Strut/Rudder assembly just for this boat, I'll take one! Let me know what ya gotta have for it.
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #189
                    Oh one other thing, Do I still need to get the UL-1 rear section for your new cowl or is your new cowl all one piece?
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2558
                      #190
                      Glad you received everything intact. I ordered a wood kit last year and all the pcs were scattered in the box and warped. It's one thing for skins to warp, but frames pcs??!! GRRRRRR!!! Anyways, I didn't want that to happen, so I gave it a college effort on the packing.
                      I'd love to offer the once pc hardware mount, but it's just not economical at this point (see attached). Too many surfaces to square up and too many operations. Maybe when I get the Tormach up and running at the shop. We'll see....
                      The cowl is complete (nose and hatch). Not necessary to purchase anything else.
                      • ray schrauwen
                        • 9471
                        #191
                        Whiplash frames always seem to be warped. Another reason to buy P-sport from you. I'm tapped out right now after buying some batteries. We'll see what happens in the next little while.
                        Nice work on that bracket. Slick! I bet you $10 the Chinese will knock it off within a year.
                        • flraptor07
                          • Aug 2013
                          • 2451
                          #192
                          Man, that is slick. I'll be waiting.....
                          • darryl whitman
                            • Sep 2012
                            • 535
                            #193
                            nice work Shooter. was the bracket cut from a block of alluim, or is it channel?
                            also can you bolt a MS rudder up to it ?
                            • darryl whitman
                              • Sep 2012
                              • 535
                              #194
                              ok , Im back workin on the boat, we had a great swap meet rc plane show , I built 12 flyin wings with other things ,
                              made 600$ in 3 hours , now I got some mad money mama dont know about , HEHE,,,
                              so now to work on the PT Shooter , started sanding, 800 grt then goto 1200grt , an top it off with 1500grt,
                              Shooter , this is why I put 3 coats on her , hope to paint an grphics on.
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2558
                                #195
                                It is made from channel, but the extrusion isn't square, so you have to mill every surface. Hopefully I will have some updates over the weekend.
