working over my mean machine ....
    • 9488
    #76
    Looks much much better
    I would say turn down your steering rate on your rudder and it should tame down your flipping issues
    • flraptor07
      • Aug 2013
      • 2451
      #77
      Brushless is right! a longer rudder is not the answer, in fact it will probably make it worse because it will turn that much quicker..
      • Rumdog
        • 6453
        #78
        Ummmm... It's a combination if both. He most definitely DOES need a longer rudder.
        • flraptor07
          • Aug 2013
          • 2451
          #79
          I'm not trying to be a smartass, He said he's got a 4 1/4" rudder on it now, how much longer does it need to be?
          • Rumdog
            • 6453
            #80
            http://www.offshoreelectrics.com/proddetail.php?prod=ros-spdr-001
            Full length. This is the rudder you want
            • flraptor07
              • Aug 2013
              • 2451
              #81
              OK but why? I've used this rudder on quite a few boats and I usually cut it to length. I know this is totally different but when I use this rudder on a P Hydro I cut it up to about 1/4" below the water pick up hole and it works beautiful. On my Cheetah I used this rudder with the dual pick up blade. http://www.offshoreelectrics.com/pro...prod=ose-80057 Here's how it corners https://www.youtube.com/watch?v=CWlC...ature=youtu.be
              • Rumdog
                • 6453
                #82
                Simply because the mean machine needs it. Its pretty well known that it needs a long rudder to corner well. I know from experience, and from the others on this forum.
                • gsbuickman
                  • Jul 2011
                  • 1292
                  #83
                  I generally agree with this and I can turn down my servo speeds on my m11 radio, however due to range issues I went back to my tactic ttx-240 so there goes that idea ....
                  • gsbuickman
                    • Jul 2011
                    • 1292
                    #84
                    new rudder & h20 pick up project ...
                    I just got the new setup on my meanie' tied up last night with a long rudder so she'll quit spinning out & handle better.
                    After some cutting and grinding with my dremel & my angle grinder, the marine specialties blade I had from an old gas hydro setup now hangs 2 15/16" below the sponsons. Now she should stay stuck to the water .....
                    Even though it took a couple hours of cutting and grinding & I had to drill the rudder mount and hang a cf tube h20 pick up on it I think it turned out pretty damn nice.
                    BTW, the boat is sitting on the stand & the rudder is even with the floor.....
                      • 9488
                      #85
                      generally its the ST.RATE knob on the tactic radio.. not servo speed
                      EPA
                      • f1rogers
                        • Sep 2012
                        • 103
                        #86
                        On my MM, from the bottom of the right sponson to the bottom of my rudder is 2 7/8". Seems long but it works great. Speedmaster 21 rudder. You can also adjust the servo throw, so it wont turn so sharp.
                        • gsbuickman
                          • Jul 2011
                          • 1292
                          #87
                          EPA
                          I will test it tonight, but that use to limit the amount of travel the servo throws, but not the speed......
                            • 9488
                            #88
                            EPA
                            Exactly! and that's what I keep saying..................
                            turn down the rate / throw of the rudder servo
                            • gsbuickman
                              • Jul 2011
                              • 1292
                              #89
                              5s test run video #2
                              Here's my 5s test run video #2 for all you good lil' boys & girls
                              I was taking it a lil' easy trying to get a feel for how the new rudder handled, as well as how well it turned at speed with where i had the steering speed set. I initally stopped it for a steerinf adjustment because it was slightly pulling to the left, after that it run straight and true. the steering speed was a bit slow and wasn't turning tight enough, although it was stuck to the water like it was on rails ie: not 1 spinout .
                              i squeezed just past 3/4 throttle and she jumped outta the water, the prop unloaded and free spun & that was all she wrote after that . I tossed out the tennis ball and pulled it in first throw and got a look inside. everything looks good but it had about 2 cups of water in it & everything was wet, esc included even though i plasti-dipped it. it worked after i got it home, but it acted like it had water inside it so i'll look at it tomorrow.
                              its still the same setup with the strut an 1/8" above the sponson's. not bad for run #2. i guess i'll start taping it cause the neoprene seal isnt cutting it, not to mention the rear hull is 5/8" thick so i cant get a seal where the rudder linkage rod passes thru the hull...
                              https://www.youtube.com/watch?v=NcU0...ature=youtu.be
                              heres a few pics of the residents and escapees from sirslashes neck of the woods....
                              • gsbuickman
                                • Jul 2011
                                • 1292
                                #90
                                5s test run video #2, pics
                                more pics
