45" Dumas Scarab
Happened about a month ago ! You may want to google it !! It was Acrylic Enamel !! I tested it and sure enough it happened on a scrap boat hull ! Turned a yellowish tint about 2 days later as it cured ! Google tells of more stories, also humidity was only 45% ! Just a fair warning and glad I saw this ! I just put mine on heavy (White Only NO Clear ) and let it sit for about 10 days and then wet sanded it up to 5000 grit wet/dry,(Started with 800 wet) then polished it to a high gloss shine !! Also Rustoleum stays soft forever !Comment
No, I used the same as you, Duplicolor Acrylic White and Clear !! Used Red also but after I saw the test hull and my buddies Hull I backed off and just took time wet sanding and came out like Glass !! Also tried other batches from other AutoZone's and they all did same thing !? Just keep edges sharp and sand and polish away !Comment
If you're going to clear it, use a 2 part urethane automotive clear and spray it with a gun the results will be much better or take it to a local body shop and have it cleared after you get everything done.Comment
Wow, close call there. I always use Rustoleum, let cure several days, wet sand and then clear with "Rustoleum" Clearcoat.................never a problem with this combo.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Hmmmm. U-pol? Started looking into it. I have a sample board I made up a few months ago just for testing. I'll sand it smooth, prime it, paint it and try U-pol out. Would rather do it all myself.
I've used Krylon before with no problems, but over on RCGroups there have been lots of complaints about it. I did use Rustoleum on my Marlin, used a flat clear coat on it but not thrilled about the final result, but it's OK. I'm a few weeks away from the clear coat anyway, if I use it. Still have lots of work to do on the hatch-cockpit and figures. My graphics from Callie will not be sent out until Monday.Comment
