Mhz c5000 1850 extreme build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #91
    Well here in good ole OZ Xmas has come around, so I'll take the opportunity to wish you all a safe and Merry Xmas before I light up the BBQ
    Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
    "Follow someone's footsteps and you will always be a step behind"
    • worriedsick4u
      • Dec 2011
      • 693
      #92
      • Xcesive8
        • Jul 2009
        • 395
        #93
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1837
          #94
          You and your pop corns lol. Ok I got a lot done without getting a lot further. There was many things missing in the previous photos shown. Nothing was glued down just placed to mark position.
          The plate was a very hard task, and to get it looking half descent took a lot of time and many attempts having to remove access excess epoxy only to apply it again.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1837
            #95
            Also got the rudder mounted, I find it easy to drill the holes as I use the rudder it self as the template. The rudder actually claps onto the mount when you tighten the screws. After I drill the top holes I simply turn the rudder upside down and drill from the button. Also, I don't like the rudder system on the inside of the hull from MHZ, I drill a larger hole to fit a black Teflon tube for the pull wires. This way also eliminates any water coming into the hull.
              • 7673
              #96
              Those rudders look sooo good Kent. Like the 'beefy' bracket style to them.
              • Xcesive8
                • Jul 2009
                • 395
                #97
                Nice work, did your rates go up on the public holidays lol ?
                Looks like you have been working right through XMAS :)
                Interesting you went with a 3rd motor down the tunnel, just thought id point out its mounted in the wrong direction..
                If you spin it 180* should be fine. Know worries thank me later
                • worriedsick4u
                  • Dec 2011
                  • 693
                  #98
                  Its a blower. Forces rpms out the ass end. Plus i wanted something in there that makes the 3060's look smaller.
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1837
                    #99
                    Lol funny! That's my spare motor for the CNC machine. But that's the only thing I could find that has a bit of weight. That thing can break 8mm bolts at only 300rpm. I wonder how big a prop it would turn
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      #100
                      @ Ryan, thanks for the tip.....LOL
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1837
                        #101
                        Got a bit more work done to the steering. Polished the pull pull clamps and soldered the stainless wires with silver solder. Next will be the lipo mounts and waterproofing.
                        • worriedsick4u
                          • Dec 2011
                          • 693
                          #102
                          Looking good.
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #103
                            Hello All, and Happy New Year!!! guess we all made it into 2014. Got some more work done. Its getting harder as I'm fitting more stuff into the boat, and at the same time trying to keep the weight down. So far about 900g of carbon. here are some pictures of the progress..
                            fr_2291_size880.jpgfr_2301_size880 (1).jpgfr_2308_size880.jpgfr_2309_size880.jpgLipo Installed.jpg
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #104
                              • worriedsick4u
                                • Dec 2011
                                • 693
                                #105
                                Sure is looking good. Nice and clean.
