Towmissel ,,,,,,I have used that x648 aswell and works great. I have tried ABC props that were recommended by other guys on this sight and although they worked they pulled some crazy amperage. I am staying with the x648.... and even that pulls 375 amps on my SAW PT45. My poor ice 240 LOL !
Phil Thomas SS45 Q Hydro Build
Todd - I take it you also own 'Pulse' packs and like them? So far, so good for me. Other guys in the class have an easy 5mph on me though. I don't think it's the batts, but they haven't been ruled out yet.
Gary - 375 amps!!! oh my!!!!! lol!!
Here's the boat @ the Mi Cup. I had to add a bright orange number on the side so I could see it! Running a prather 245, detounged. Thanks to Doby for taking the vid:
Here's the prather I was running....could probably remove more material, like towmissel's prop.
IMAG0159.jpgComment
http://www.youtube.com/watch?v=40Dtk...x9OzK2el4P3E6g
and I have a PSpec PS295 that is about 5mph faster than second place and that's with my Turnigy packs... LOL.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Data from the runs at the Elks club.... The third run is with the Prather prop in the photo above. Let me know what you guys think. I thought I was pushing the limits with the X457.
Presentation1.jpgComment
OK. Per Jimmy's recommendation, I cut some material off the 457... Major de-tongue job and some material from the hub.
X457_dt.jpgComment
That's some mighty fine work there. Should reduce amp draw and give you a little more top end. Hopefully I start a positive batting average with this advice. I'm 0 for 2 between the strut adjustment and the canopy leaking. :-)Comment
I forgot about the canopy suggestion. lol!
I took a close-up photo of the P245 and X457. A lot of blade area difference.
IMAG01652.jpgComment
i see you have a neu motor in this hull did you shorten the motor shaft i took my castle 1717 out and replaced with a neu 1527 and i can't get my colett on and need to know if you can cut part of the shaft off or is it a bad idea thanks, genoComment
On my saw rigger I had to cut 3/16 "off the shaft of my Neu 1527(... I see no problem in your case.GillGO FAST AND TURN RIGHT !
www.grsboats.com.brComment
Clueless - So far, I haven't noticed much difference in either prop (X457 modified vs. Prather S245), so I am sticking with the Prather S245.
For some reason however, my current draw is significantly higher than before....on ALL PROPS. Last time I logged data, the outside temps were around 95ish. I think the heat may have something to do with it. Anyone observed this??Comment
Pete
where did you do the first data log if it was at the elks and this was form yesterday at Shelby
there will be a difference the Shelby course is shorter and not as wide so it will cause you to pull more amps
at the elks it is a longer wider course
FredWhen all else fails floor itComment
