Phil Thomas SS45 Q Hydro Build
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    I've been asking a ton of questions lately and getting a lot of help (THANKS!), so I figured I would give back a little and share my latest build. Hopefully it will help someone else out.
    Hull: Phil Thomas SS45 SuperSport
    Motor: NEU 1527 1Y
    Purpose: Q Hydro
    1. Started by cutting apart the canard wing. I used an exacto saw to cut straight.
    2. I cut the slots in the sponsons with a dremel.
    3. Used a tape guide and glued them in with epoxy.
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    4. Decided to go with a Williams 5" rail motor mount. Top notch stuff from a top notch guy at South River RC. The rail mount should make the boat a little stiffer. There is a lot of wide open space for flex. I also plan on adding a carbon fiber rod up front aligned with the turn fin.
    5. I made (4) aluminum backing plates to support the mounts. I also threaded the holes in the backing plates so no nuts were necessary. Made it a little easier to get it together.
    • Shooter
      Team Mojo
      • Jun 2009
      • 2558
      6. It was a bit of a struggle to get the backing plates in place, but nothing a popsicle stick and some sticky tape wouldn't handle.
      • Shooter
        Team Mojo
        • Jun 2009
        • 2558
        7. Turns out that an old collet makes an excellent pin vice! LOL!! I have a 90° attachment for my drill somewhere around here, but this got the job done.
        • Shooter
          Team Mojo
          • Jun 2009
          • 2558
          I made this turn fin and bracket last year by tracing a friends. Hopefully it will work. It's pretty hefty!
          • teetriple
            • Jul 2008
            • 195
            Looking good Pete you might what to put some glass on the canards were they go in to the hull to reinforce that area with the speeds we are running in Q sport mine started to crack in that spot until i put some on mine . Get that thing done love to see it running at are next club race
            • longballlumber
              • 3132
              Good work Pete! I like the coupler idea for the drill bit. I am going to steal that one!
              Later,
              Mike
              • Shooter
                Team Mojo
                • Jun 2009
                • 2558
                Tony - Thanks. Did yours start cracking on the inside of the sponsons? Or the canard itself?
                I hope to have this done by next race. Rudder is on it's way from OSE! I think that's all I need.
                Mike - What paint did you use on your orange Uhaul boat? That seems to hold up pretty well.
                • jfrancisco892
                  • Feb 2012
                  • 546
                  Looking good pete. Planning on having it done for the next race?
                  • teetriple
                    • Jul 2008
                    • 195
                    It was on the sponson were the canard go's in to it
                    • longballlumber
                      • 3132
                      www.klasskote.com 2 part epoxy paint. When that shift cures it's hard as a rock!
                      Later,
                      Mike
                      • jfrancisco892
                        • Feb 2012
                        • 546
                        Lol. Didn't see that post.
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2558
                          I hope so. I've really been dragging this one. Had the hull since October I think.
                          • Gary
                            • Jan 2009
                            • 1105
                            This is a great hull! I had to modify the nose to except 2 5000 6s batteries but other than that it was a fairly easy build. These hulls are stable as can be at 100 +. Your going to love it. Good luck.
                            H&M 1/8 Miss Bud 73 mph
                            Chris Craft 16 mph
                            • Shooter
                              Team Mojo
                              • Jun 2009
                              • 2558
                              Thanks Gary. I remember watching your trials at around 90ish. I take it you did eventually hit 100? Amazing. I'll check your threads. Would also like to see that nose modification.
