ProBoat BlackJack Twin Build
    • 7673
    #61
    Originally posted by mtbenjamin77
    I finally got a chance to do some work on one of my boats this week. I'm working on 14 different boats it's hard to find time for my own, and by the time I do I'm to tired to get anything done. ha. Anyhow I'll post some more pics later.
    14 boats!!! I wouldn't find time for work.And would be overwhelmed.
    • HYDROJERRY
      • Jan 2010
      • 2503
      #62
      You would have to charge alot on 14 different boats so you wouldnt have to work, hahaha.
      • mtbenjamin77
        • 761
        #63
        currently Im working on setup/rebuild
        SGX 90
        Vision 40
        HTB 20
        KEPS 20 twin BL scratch build
        Delta Cat twin
        FC Daytona
        Vegas BL conversion
        Motley Crew Upgrade
        Revolt 30 Rebuild
        PT 109 scratch build
        Mini Cat twin BL upgrade
        Recovery Boat scratch build
        Aquacraft Tug convert to BL
        Blackjack 29 twin
        Pursuit Mono
        • mtbenjamin77
          • 761
          #64
          I'm so burned out I getting tired of my favorite hobby. That sucks. I think I need a vacation.
          • properchopper
            • 6968
            #65
            [ATTACH=CONFIG]88859[/ATTACH][ATTACH=CONFIG]88860[/ATTACH]
            With the extened fuel tubing I can tighten the motor screws from outside the hull. Then I just use a standard 90 degree allen wrench to toque the screws down tight. If I can find some 3mmx10mm knurled cap screws that'd make it even easier
            • HYDROJERRY
              • Jan 2010
              • 2503
              #66
              I her ya Mtbenjamin,, i have been rebuilding a 4wheeler and ive pushed the boats aside for awhile, kinda taking a brake from them myself but i also realy wanna get the 4wheeler wright before say before x-mas so its getting all my atention for now plus its cold her and i dont do well in the cold so no boating anyway!!!
              • mtbenjamin77
                • 761
                #67
                I've made some progress on this build. I have both motor mounts in place and both stingers with stuffing tubes installed. I wanted to be able to replace the stuffing tubes without removing the stingers so this is what I came up with...
                It may cause the stingers to wear faster although I can easily replace them once they wear out. The fuel tubing is for the oiler. The photos show, in order, how the unit is assembled. Then the entire unit slides into a larger brass tube glued into the carbon fiber stinger tube
                • mtbenjamin77
                  • 761
                  #68
                  Next step will be reinforcing the motor mounts. Here I've made paper templates for the reinforcing CF. The inside has been lightly sanded to help the reinforcing adhere. A final thinned coat of finishing resin will be applied once all components are installed.
                  • Rich
                    • Jan 2008
                    • 551
                    #69
                    I take it that tube coming out of the stuffing tube is where you are going to use an oiler?
                    24 R/C vehicles and still counting...What budget?
                    • mtbenjamin77
                      • 761
                      #70
                      Yes, here you can see the oiler hose running up to the oil filler on the deck. The two black dots on the deck are my oil fillers. They're fuel dots used for gas powered rc airplanes
                      • Rich
                        • Jan 2008
                        • 551
                        #71
                        I like that idea! I could even put a grease nipple and use a grease gun
                        • mtbenjamin77
                          • 761
                          #72
                          grease wouldn't work as good as oil. the grease would just come out at the collet and never make it down to the strut bushing.
                          • mtbenjamin77
                            • 761
                            #73
                            here's the installed CF motor mount reinforcing
                            • olwarbirds
                              Magic Smoke Wizard
                              • Oct 2012
                              • 1136
                              #74
                              Nice, I really like the oiler idea. What kind of oil do you use instead of marine grease then ? DJ
                              • mtbenjamin77
                                • 761
                                #75
                                heavy weight gear oil
