anytime you have a positive or negative angle on the stingers you are giving up speed for better handling. I set my stingers at exaclty 0 degrees toe and trim use the COG to adjust for water conditions. If you look at the toysport hulls built by joseph toth they don't use an adjustable stinger If a boat is built and balanced correctly you shouldn't need adjustable drives.
ProBoat BlackJack Twin Build
Hey sorry to intrude, BUT if you want to try a dual-motor 120A + 120A speedy, LMK - hit me at [email protected] to discuss
[ATTACH=CONFIG]88709[/ATTACH]
DSC02966.jpgDSC02967.jpgComment
Made some prgoress today. I have one motor mounted and aligned. I ran the motor at low speeds with oil in the oiler to break in the drive and it's smooth as silk.
DSC02968.jpgDSC02969.jpgDSC02971.jpgDSC02972.jpgDSC02973.jpgComment
I had to wipe the drool off my kybrd again, after looking at those pics...nice work !...I was also wondering about the non-adjustable stingers, but do understand now why they dont need to be...sure makes my twin setup a bit less expensive and easier in the long run...tks .. DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
DSC02969.jpgDSC02970.jpgDSC02972.jpgDSC02973.jpgDSC02974.jpgComment
With the extened fuel tubing I can tighten the motor screws from outside the hull. Then I just use a standard 90 degree allen wrench to toque the screws down tight. If I can find some 3mmx10mm knurled cap screws that'd make it even easierComment
I've seen Travises work first hand as he has is some fashion had a hand in helping if not building the 5 fe boats I'm currently running . I wish I could do some of the things he is capable of with his creativity. And the blackjack he is building will truly be one of a kind.Comment
That works for me. can't wait to see the river cat run. I ran the twin delta explorer today. I only used 5S for the first run. It ran really goodComment
I finally got a chance to do some work on one of my boats this week. I'm working on 14 different boats it's hard to find time for my own, and by the time I do I'm to tired to get anything done. ha. Anyhow I'll post some more pics later.Comment
