ProBoat BlackJack Twin Build
  • mtbenjamin77
    • 761
    I picked up this RTR package at the hobbyshop the day they were released. It never touched the water before being gutted for twins. Here's some pics.
    The cardboard cut outs are my templates for carbon fiber pieces
    Here i've cut out the exsting stuffing box
    • 7673
    Oh,you are a brave sucker.I just finished the Geico and it is tight in the back there.Got your patience pills handy?Motor bolts were the issue.
    But don't get me wrong, I LIKE IT
    • mtbenjamin77
      • 761
      The stingers will be made of carbon fiber tubing with brass lining and a brass strut bushing.
      Here i've lined the sidewalls and transom with Carbon/kevlar cloth.
      • mtbenjamin77
        • 761
        yeah I had the same problem with a delta cat I built recently. I made a special tool to get the motor screws started then just had to tighten them with a regular allen wrench
          • 7673
          A piece of silicone tubing on either a 1/4 drive allen key(screwdriver type) or even on the bolt itself works.Give you a little something better to grip with your fingertips. Of course I didn't think of that till final assembly
          • mtbenjamin77
            • 761
            This shows how the motor mounts will sit and be glass in place. The cardboard patterns were traced to some scrap plywood so I can mount the motors and get a good feel for were they will be positioned in the hull. I had to adjust the mounting holes so that the motor shaft would line up with the stingers. I also want the motors to sit as low as possible in the hull. the motors I used are just for mockup so I made sure my mounting holes were drilled so I have some leeway on what size motor I can use. I left plenty of room to fit a pair of 40 series if need be.
            • mtbenjamin77
              • 761
              I just finished laying up the CF inlay. I ran it up as far as possible under the front deck. I have one last layup to do and I'll be ready for hardware installation.
              • mtbenjamin77
                • 761
                These hulls have a tendency to split along the seams in the front. The sides have the inlay but the center bow at the tunnel only has the factory seam.. So what I do is take some left over cf fabric and chop it into very small fibers. Then I mix up some 30min epoxy and mix the fiber in creating an epoxy/carbonfiber kitty hair type resin/paste. Then simply apply it generously right at the front seam at the tunnel.
                • mtbenjamin77
                  • 761
                  Here's mine.............
                  • Rocstar
                    Joel Mertz
                    • Jun 2012
                    • 1509
                    Very Cool!
                    • Jersey Crewmax
                      • Jul 2012
                      • 443
                      Looks good, looking forward to seeing the end product.
                        • 9488
                        I dig these small twins!
                        Looks cool man..
                        I would love to try twin 3674 2650kv motors in my MM
                        • mtbenjamin77
                          • 761
                          Looks cool man..
                          I think I'm leaning towards 3674 1700kv on 6S, But it designed to fit up to 4074's.
                            • 7673
                            I also put a stringer down the center under the deck.This will eliminate the deck pushing in and cracking the side seams in a blowover.
                            Just sayin'. Blowover will be inevitable with 40mm motors.
                              • 9488
                              you would have plenty of power to run as fast as you like
