35" DF Pirate 1st build.
  • tlandauer
    • 5666
    #76
    Regarding space: you are getting great advices. I had problem with my build because I wanted to use a Peter Z motor mount which widens the foot print much more than yours. Little I could do to help myself, I made sure every bolt/screws have hex head so I can use this tool: http://www3.towerhobbies.com/cgi-bin...?&I=LXDPX6&P=7. No Nhilips head for me, this shortened " L" version is a wonder.
    • KartRacer
      • Aug 2012
      • 355
      #77
      Originally posted by lenny
      Hey,
      You should rethink your setup inside of the hull,
      Down the line you may want more speed and bigger cells to do it with,
      So just trying to think a head for your setup in the future.
      Your servo, Like 3" from transom next to the stuffing and receiver on other side of tube and than cells,
      And than motor and esc,
      If your stuffing tube is to short and low it will let water in.
      Hear link for some info on that hull.
      http://forums.offshoreelectrics.com/...35-quot-Pirate
      http://forums.offshoreelectrics.com/...Pirate-Rebuild
      Lenny
      The two threads show one with motor to the front and the other to the rear. I thought the shortest driveline was the most efficient and least troublesome. Am I wrong on that theory? I could easily move motor to front with longer stuffing tube and place everything else to the rear. Is there a Prefered layout of the power system. The two 3 s batteries will be heavy and figured them to be the best to move around for cog setting.
      KartRacer ~ Dennis B
      Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
      • KartRacer
        • Aug 2012
        • 355
        #78
        Tlandauer
        Tools are not the issue, I am lousy with tools. Lol
        Again I would like to know the preferred setup.
        I'll be CF/Kevlar the hull in the morning and then will need to decide on the layout.
        Also, the stuffing tube as it is , short, has a slight bend to it to get the tube level with hull on exit. I had read somewhere about a s bend in another thread. Is one preferred over another.
        • KartRacer
          • Aug 2012
          • 355
          #79
          The 4092 motor has 5.5 bullets on it. I have 6.5 bullets on hand and will use them on all other connections with 10mm wire. Should I change the motor bullets? Also i will be putting in safety shutoff loop on hull and planned on the 6.5 bullets there also.
          Canopy hold downs , should I put in aluminum latches or is tape sufficient. Planned on slide in pin on the front with latches on the rear. Don't want to over build if not necessary.
          Thanks.
          • KartRacer
            • Aug 2012
            • 355
            #80
            Originally posted by dana
            Yeah, move it to another location or use lay down type mount
            Dana
            Can move stuff anywhere at this point. Does length of push rod matter. Using 4-40 rod.
            • KartRacer
              • Aug 2012
              • 355
              #81
              Make a wake
              Was planning on one water feed from rudder to motor mount, then through motor jacket and out the fitting. The other rudder feed would cool the ESC then out the other exit.
              Sound logical?
                • 7673
                #82
                Originally posted by KartRacer
                Lenny
                Hey there Kart,just thought I'd throw this out there for "food for thought".I have a DF 35" (not Pirate),I haven't compared bottoms but I'd bet they are the same if not real close. Here is how mine is setup: I run 4 3s batteries to make 6s2p.I hae two behind the motor on the CF tray and one on either side of the motor able to go forward or back.
                And here is a vid http://www.youtube.com/watch?v=1XOGvQroid0&feature=plcp
                I have vids of it when it was all hoppy.
                And as it gets faster it needs the batteries as far forward as possible.
                And it has been cleaned up a bit since this pic.
                • dana
                  Banned
                  • Mar 2010
                  • 3573
                  #83
                  Dana
                  nah i dont think so, but i generally keep them somewhat short. the ul1 servo is mounted way up front and uses a long pushrod without issues, so whatever you choose should be ok
                  • lenny
                    • Sep 2010
                    • 4293
                    #84
                    That is what I am taking about,
                    Very nice setup, Nice and clean and hatch bolts with a seal.
                    ? ONLY IF THEY WORK
                    • Make-a-Wake
                      FE Rules!
                      • 5557
                      #85
                      Make a wake
                      Sound logical?
                      Yea, one line for the ESC and one for the motor..................seperate exits too.
                      • tlandauer
                        • 5666
                        #86
                        Tlandauer
                        Yes, I know tools are not the issue, I was trying to not get in your way and other people's way, what I was trying to say is as long as you can get in and perform all the adjustments and maintenences with essential tools, with reasonable consideration given to logical layout, don't lose sleep over it, you need to decide what's best for you with your gut feeling after absorbibg all these info.
                        I have seen "S" bends on cats and hydros, your notion about the stuffing tube in your case is correct.
                        • Scott T
                          • Oct 2007
                          • 590
                          #87
                          Dennis,
                          Some dimensions from my DF21 mkII if you're interested (all from outside face of transom) -
                          Middle of servo - 3"
                          Mounting face of motor (shaft end) - 6.75"
                          Middle of ESC - 11.5"
                          Rear edge of 6S1P battery - 13.5"
                          You've seen my thread, so you can see the layout. It is very easy to maintain and the boat is a rocket. You'll have to adjust your distances slightly as your hull is shorter, but it might give you a starting point.
                          If you go for 4 x 3S packs (6S2P), you'll need to do something a bit different. Hope that helps!
                          Scott
                          Scott Tapsall
                          Pine Rivers Model Powerboat Club - Facebook Page
                          My Gallery
                          • KartRacer
                            • Aug 2012
                            • 355
                            #88
                            Tremendous help everyone, thanks! Ill look things over again and make layout changes and post before I dive in with epoxy on mounts :)
                            • KartRacer
                              • Aug 2012
                              • 355
                              #89
                              Originally posted by Scott T
                              Dennis,
                              Scott
                              Scott
                              Any idea on run time I'll get with the 2x 3s setup verses the 4x 3s setup. Should I plan for adding the extra two batteries now or can that change at a later date?
                              Running setup in my sig line.
                              • dana
                                Banned
                                • Mar 2010
                                • 3573
                                #90
                                Two 3s packs won't get you more that 3 minutes on a good day. Can you run two 6s packs parallel instead?
