Have fun with it, post something as I want to learn kevlar/CF reinforcements. I kind of avoided that by just using heavy weigh FG cloth to strengthen my hull up to now.
Don't know about the extra layer of CF's affects on 2.4 Ghz radio transmission. I know if the hull is CF, then you must route the antenna outside. I use Tactic which has no antenna, but only on FG hull. On the boats where I use Spektrum Marine Radio system I have done both ways, one outside and one inside ( receiver has two wire antennas).
I tried to run them both inside but I tape one under the hatch with electrical vinyl tape. ( the higher it is from the water , the better) It worked on the Delta Force 26. But on my MHZ Lizard Xtreme, it did not work so well: maiden came to an abrupt stop due to loss of signal and the receiver automatically goes to NO Throttle. ---forgot the term for this situation.
I would put the antenna outside if I were you, it looks like it is on the short side so it would not be a long stick poking out. Just my $.02.
