  • izcain
    • Mar 2012
    • 274
    #1186
    There ya go man sounds good!
    Are you running 2 in series or Parallel ?
    • izcain
      • Mar 2012
      • 274
      #1187
      I think it's good that you have to work out the bugs with the strut now you know what happens when it is at each position!
        • 7673
        #1188
        Originally posted by masonis1
        Haha there ya go... Ill fix the linkage. Ill take it out, straighten it and start fresh. Ill do that soon. And ill cut the butts off and solder them up. Hah
        Sent from my PG06100 using Tapatalk 2
        Thats good bud.The rod is probably sliding in the servo horn.All the manuals are on traxxas's website.
          • 7673
          #1189
          • masonis1
            If you cant control it 👍👍
            • 1173
            #1190
            Originally posted by srislash
            Did I go through this with you Mason?I don't remember if it was you or not.Put the boat flat on the table...
            Dont set it on the stand?
            • masonis1
              • 1173
              #1191
              2 in series.
              • masonis1
                • 1173
                #1192
                Yep. I know it bounces now and... When up.
                • izcain
                  • Mar 2012
                  • 274
                  #1193
                  I bet that was maybe touching 35-40 in some spots!
                  • masonis1
                    • 1173
                    #1194
                    Ya i know but i just wanted to drive it. Im gunna call tomorrow, and try and solder the wires.
                    • masonis1
                      • 1173
                      #1195
                      Hah i was hoping for a litle faster but in real life, its fast... Almost too fast too soon. Once i get it on a big lake and can see how it will go when i open her up for a bit
                        • 7673
                        #1196
                        Put the boat on a table with the bottom of the strut on the table too.Loosen the strut bolt slightly and push the hull flat on the table.The strut should also be flat on the table.Tighten the strut like that.
                        • izcain
                          • Mar 2012
                          • 274
                          #1197
                          You can find the manuals online there mason and that should help you get the settings reversed
                          I will look here in a minute and see if I can find the link and post it for you.
                          • masonis1
                            • 1173
                            #1198
                            Ok thanks and thanks. So should i just start at the flat strut with the bottom or should i move around after that? Is that what u run?
                            • izcain
                              • Mar 2012
                              • 274
                              #1199
                              • masonis1
                                • 1173
                                #1200
                                Ill do this tomorrow.. i will need to clean off my coffee table and use it. All my other tables have lips on them
