Also, what does the 113 sticker on my boat mean?
I need some females and a series. Thats it. And i dont know if i can get to the hobby store because my mom had surgery and cant drive so.. hah im gunna try to bug my friends to get me a rideWhen speed isnt the option, change your waysComment
So whats blueprinting the hull do for performance? And how hard is it to do? I think i will run it stock for a while and once i get use to it i will turn up the boat and fix er up.When speed isnt the option, change your waysComment
Hopefully my friends can get me a ride to the lhs today and i will get some connectors, series connector and a balancer plug adapter. Then once i get all that, ill have my dad drop me off at the test lake and ill lube up the flex and take er out.
This is if plans go wellWhen speed isnt the option, change your waysComment
So.. i sharpened the rudder and strut with a file to give it a clean cut through the water. I didnt find any leak or water in the MG. Great thing to find. I tightened everything up and then... I added a piece of steel wire from the strut to the offset rudder piece to do two things, keep it from moving around if any and if something comes loose, i wont loose the piece. So that should do something. I also added about 9 packaging air bags in the hull, 3 in each pontoon tip, one behind the motor and one behind the battery tray. This thing wont sink now at all. Hah so i think this should work. Ill post pics laterWhen speed isnt the option, change your waysComment
