  • masonis1
    If you cant control it 👍👍
    • 1173
    #781
    Still nothing on the prop. So an octura x440?
    Sent from my PG06100 using Tapatalk 2
    • izcain
      • Mar 2012
      • 274
      #782
      Sounds like it was be a good start. I am really curious how this hull is going to handle all this newfound power lol.
      • masonis1
        • 1173
        #783
        Hah ya. I mean it twists with the torque out of water.. hah so the octura or what?
        • Make-a-Wake
          FE Rules!
          • 5557
          #784
          Thats the largest i would go...............a 438 is probably better. You're gonna be able to pull "wheelie's" off the line ya know!!
          • masonis1
            • 1173
            #785
            Hahah ive seen an awesome video where a miss long lite jumps out of the water like a foot and lands then shoots off. Hah.
            • masonis1
              • 1173
              #786
              Damn props seem very expensive
              • masonis1
                • 1173
                #787
                http://www.youtube.com/watch? v=lhZlQtoya6s&feature=youtube_gdata_player
                I want this!!! Just in my boat...
                • izcain
                  • Mar 2012
                  • 274
                  #788
                  I would start off as small as I could find something like the 35mm and work up. That is going to have a ton of bite with a big wheel on.
                  • masonis1
                    • 1173
                    #789
                    That small prop will?
                    • izcain
                      • Mar 2012
                      • 274
                      #790
                      I think I would just buy some plastics and then drill the centers out to suit your larger prop shaft for now and try them out. Once you have a proper prop setup then I would invest in a nice copper or stainless one. But thats just my .02
                      • masonis1
                        • 1173
                        #791
                        I have some smaller ones but i think they will be weak with so little of the coupler left
                        • sailr
                          • Nov 2007
                          • 6927
                          #792
                          Originally posted by masonis1
                          For the transom??? Could i add a piece of plastic of aluminum to stiffen it up? Also, what were the things for the drive lines i needed. Everything i get here should be able to cover over onto a different hull correct?
                          Epoxy some 3/16" plywood on the inside of the transom and then seal it good with more epoxy.
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • masonis1
                            • 1173
                            #793
                            Its already finished... I put a piece of plastic in..
                            • masonis1
                              • 1173
                              #794
                              I have like a couple octura 431 and up...
                              • masonis1
                                • 1173
                                #795
                                Too hard to drill out so im gunna try another prop i have.. unknown stats.
