I dont know ANY%ING about props
I have a aluminum 30,and an old 35.But herein lies another problem,might need a stepped down shaft.I have a spare Proboat plastic prop 40mm.I haven't got anything in the 37-38 range yet. M-a-W should have an idea as he has a couple of these motors so should know what they will push.
Happy Easter eggs to you's as well.Comment
Sorry Mason,The numbers change around a bit but for Octura props they will call it X 430.That is 4=1.4 pitch or 1.4 x diameter.And the 30 will be that diameter of the prop.Other's will list as 4518(such as ABC props)which will be 45 mm diameter and 1.8 pitch.As you increase pitch you are usually increasing speed but lose a little off the start.More pitch also increases amp draw. Questions?Comment
You ever figure out what size diameter your shaft is?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
For your flexshaft?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
