  • masonis1
    If you cant control it 👍👍
    • 1173
    #196
    Ok so i can buy that one? How would i need to make the stand?
    • h2o 1
      • Sep 2011
      • 770
      #197
      I dont think you need to buy one,just make one out of a piece of wood.It will go between the transom and the strut on the outside of the hull.Give me the dimension of the srtut bracket and i will make one for you and send it with the other things im sending tomorrow
      • masonis1
        • 1173
        #198
        I dont know the dimensions of the rudder bracket. I will try ordering it tonight or tomorrow.
        • masonis1
          • 1173
          #199
          So i told they guy i will get the one from ose but used. The one izicalt or whatever has.
          • h2o 1
            • Sep 2011
            • 770
            #200
            Thats no problem!I will send one and you can just sand to ur liking!
            • masonis1
              • 1173
              #201
              Ok great. Thanks again.. you are helping me so much by sending this stuff.
              • masonis1
                • 1173
                #202
                Thank you so much
                • masonis1
                  • 1173
                  #203
                  Ok so just finished putting the first coat on. Going to keep the colors secret for now. Atleast until i finish prepping for the final color..
                  • masonis1
                    • 1173
                    #204
                    What i can tell is the design.. there will be a strip that raps around the front of the hatch, down the side and curve out to a strait line around the transom.
                    • masonis1
                      • 1173
                      #205
                      Just sanded the first coat of main coat, giving about an hour and a half to dry before i lay tape. Its really smooth. Sanded, got scared when the color dulled but it made it very smooth and now its perfect.
                      • masonis1
                        • 1173
                        #206
                        Last coat for main is on. How can i cut tape on the hull without hurting the paint below?
                        • blizard05
                          • Jun 2007
                          • 576
                          #207
                          Originally posted by masonis1
                          I would make a new bracket for the strut,and use the ruder as a offset
                          America home of the free, thanks to the brave [/url]
                          • Make-a-Wake
                            FE Rules!
                            • 5557
                            #208
                            I'd run this if it were mine......................i was hoping to find a 4mm strut/rudder combo, but this stinger is about 2.7" long
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              #209
                              Found one!
                              • masonis1
                                • 1173
                                #210
                                Those are prettu expensive... Hah
                                Anyways, just put the firt coat of the second color on... Pissed tho cuz the boat fell off what it was sitting on. Lucky i was only painting top so it should be good. Im not big on paint.. but i think it will be ok
