coopers shocker build #2
  • Cooper
    • Jan 2011
    • 1137
    #121
    Originally posted by srislash
    Thats cool.I have yet to find an accomadating vinyl person.I have a set of three pages of sponsors and numbers to do up. I managed to get my decals fairly smooth and they cover the couple places that I went through the CF.My seams were ugly IMO.If I ever get another CF hull I'll ask a bit of info.So what clear are you to use?
    i probably going to use u-pol or thought about the 2k 2part spraymax urethane aerosol clear coat, two part clear in one can. pretty cool has an inner cylinder that you puncture then mix and have like 24 hours to use it. in a rattle can and about $15.
    • Cooper
      • Jan 2011
      • 1137
      #122
      Originally posted by RCKong
      Say, hear is something to think about - how long will it take you to get into that hatch with all those bolts ? Trust me If you have electronics on fire in the hull you want to be able to get in there fast. I would think 4 of them would do... just sayin
      Yup, I thought about that and will be running without the two front and back for sport, when running for speed they are all going in. The bolts are loose and the holes are like 1/8" or so they will be very easy to tape over. And that was the main reason I like to see inside, smoke/water. Hopefully that will never happen! Lol... I just didn't like the two pins in the front and the big hatch locks ( the ones with the springs.. And not much room for tapeing around them) in the back. So that was the thought into that one. I'm working on a fool-proof magnetic locking hatch system, where you use a magnet for a key to release locking pins, super smooth clean look! But that's another build when I get it figured out.
      • RCKong
        • Sep 2009
        • 1554
        #123
        or maybe actually having a key that would release locking cellinoids...hmmm 2 car door locks would run 4 hatch bolts, and they run on 12v or maybe even 7.4v
          • 7651
          #124
          And a remote.Hehe
          • RCKong
            • Sep 2009
            • 1554
            #125
            or touch pad entry
            • Cooper
              • Jan 2011
              • 1137
              #126
              That would be pretty funny, have your car keys out and hit the button for the rc boat hatch to open, would have to get it to chirp twice also !!!!! Lol!!
                • 7651
                #127
                Love it,let us know when it's perfected.
                • RCKong
                  • Sep 2009
                  • 1554
                  #128
                  • runzwithsizorz
                    • Jan 2009
                    • 856
                    #129
                    Originally posted by Cooper
                    i know the knurled bolts are going to be an eye sore on the looks but its necessary . im working on a seal under the hatch. not sure about that, im leaving just enough room next to the bolts to get some tape on. would love to run without tapeing the hatch but i just dont feel secure enough to.
                    With that lip around the edge of your hatch, you may want to use a slightly thicker variety, or shave the lip,(I did). That way your kopious, konspicuous, knarly, knurled knobs will give you a kewl seal.
                    Oh, and thanks to your inspiration I've spent the last couple of days turning flat sheets of acrylic into various pieces of, umm, art?
                    • Cooper
                      • Jan 2011
                      • 1137
                      #130
                      Originally posted by runzwithsizorz
                      [ATTACH=CONFIG]71630[/ATTACH]
                      I have to look into that stuff, foam tape,
                        • 7651
                        #131
                        This stuff is real soft and available at Home Depot.I've had great success with it on my Shocker.And pretty good on the Miss Geico.
                        Oh,and available in different shapes.
                        • Cooper
                          • Jan 2011
                          • 1137
                          #132
                          i found this craft foam, 1/8" to 1/4" thick and adhesive backed too. they have larger sheets, big enough to make one piece for the hatch lip. so no seams. i sanded down the hatch edges so it is basically blue-printed to the hull, so the foam seal should work pretty good. and that was also the reason why so many hatch bolts. im hope i can run without tape, will have to test it out in the tub..
                          • Cooper
                            • Jan 2011
                            • 1137
                            #133
                            [ATTACH=CONFIG]71655[/ATTACH]
                            thats where i have to go look for some other stuff, i have a lowes near but home depot is next town over, have to head there this weekend
                            • Cooper
                              • Jan 2011
                              • 1137
                              #134
                              i had these laying around so figured why not use them.
                              • Cooper
                                • Jan 2011
                                • 1137
                                #135
                                my cheap radio shack 40 watt sodering iron was no match for those 8mm bullets with silver soder....
                                yea right. lol... it didnt even get the soder hot enough... so had to use the torch, well it worked out better than the soder iron ever
                                i also cut the wires shorter. and yes the bullets are not pluged in the whole way.. damm those things are hard to get apart,, please tell me they will losen up with use,??? i know they are for the motor/esc connectors but i thought about using for batteries. if thats how hard they are to get apart then no way. im not a pansey, i litterly needed to use plyers to pull them apart when they were unused just bare bullets.
