32" River Cat
  • Howard Lee
    • Nov 2010
    • 198
    #31
    Originally posted by Mike
    ok no problemo
    for my last run with my medium mystic 1527 1.5d on 10s propshop 5018/3 i reach 112 mph.
    8s propshop 5018/3 = 98 mph
    but i don't test 9s , i thing we can pass the 100 mph
    so i would like to see your 11s in action 125mph
    but i use a big propeller to reach this speed and you, you want to use small propeller??
    there are so many surprises in the rc boat so i'm looking forward to see your projet in action
    Mike don't do that!! We don't talk about mph, 112.... lol... and then telling everyone about 125... MIKE!! lol...
    Now on a serious side with your 1527 did you drill a small hole or put a flat spot on your output shaft?
    With my 32" the prop that worked was a 48mm and i hit 90.5, when i would go up in prop size it would push the boat all over. If i can run the 48mm and get more rpm then it would be stable. Small hulls like big rpm's and small prop's.
    • mike76
      • Dec 2008
      • 102
      #32
      yes i put a flat spot on my output shaft and this part:
      http://www.mhz-powerboats.com/mhzpow...fb5d5cef8b35b0 for safe my cable flex
      the 1527 is very power full, i broke 4 time my cable flex .
      did you put something on your esc swordfish to waterproof it?
      • Howard Lee
        • Nov 2010
        • 198
        #33
        I guess its powerful, 4 drive shafts.
        No, i never waterproof my esc and it has got wet but never had a problem. If i get some water in the boat ill use a hair dryer or i have powerful floor fan that works good.
        • keithbradley
          • 3663
          #34
          Hey guys, the swordfish 240 comes with a water resistant coating already on it. It will wear down over time, but can be acheived by applying corrosion x, available at OSE.
          www.keithbradleyboats.com
          • Howard Lee
            • Nov 2010
            • 198
            #35
            Is that what you put on your esc, if so I'm not putting it on my s/f. Thanks for the info.
            • mike76
              • Dec 2008
              • 102
              #36
              Thanks for the info
              • Howard Lee
                • Nov 2010
                • 198
                #37
                Hey guys
                I'm working on the river cat and it looks good. My motor mount will be in 2morrow and i can get it going. I'm thinking next weekend it will be ready.
                I want to talk about what this hull is going to be built for. This is going to be for top speed only. Ill compare it to a top fuel car. I don't think you'll see a top fuel at Daytona speedway. lol... It will have a short rudder and high prop height. I'm looking to run the rpm's as high as i can. If my motor is a 10s max and i run 10s and i run this setup and go jumping my wake it would be very stupid of me. When you jump your wake with a prop that is half in the water it will free spin and the motor will blow. If you run a 10s motor on 5s I don't think is a big deal but i still would not recommend it. There is a big difference in a race setup and sport and knowing the difference. Ill have some pics this week.
                • Howard Lee
                  • Nov 2010
                  • 198
                  #38
                  • Old Sloppy
                    Harry from Atlanta
                    • Jul 2007
                    • 200
                    #39
                    Oh Yea ........
                    Harry
                    from Atlanta
                    60" Expresscraft SuperCat
                    (2) 2028 Castle motors 64.7 mph
                    10s3p with x450/3 props
                    15,000 mah 40c cells,
                    • Howard Lee
                      • Nov 2010
                      • 198
                      #40
                      Check it out.
                        • 9488
                        #41
                        very cool!
                        • Old Sloppy
                          Harry from Atlanta
                          • Jul 2007
                          • 200
                          #42
                          So when will it see water ?
                          I can hardly wait..
                          Harry
                          • Boaterguy
                            • 1760
                            #43
                            Check it out.
                            I didn't know you could fit all that SEXY onto a single table!
                            when do we see it in the wata?
                            • rcboatmanwithkids2880
                              • Aug 2008
                              • 340
                              #44
                              Hi Howard ,
                              Your pushing the boundries of F/E , so we all should thankyou for posting your journey thus far with your 90 mph effort . What i am most impressed by is the fact your using s HOTR CAT , which has many doubters , i run one & think that it's a very capable hull & your proving it !!!!
                              Seem to remember another Howard who was pushing the engineering limits who had his doubters in history ( Howard Hughes ) .....
                              All the best mate ,
                              Brad
                              Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
                              • Accordnut
                                • Jan 2011
                                • 19
                                #45
