Larrys 32" twin cat
  • johnson22456
    Counting down the days...
    • Jul 2008
    • 218
    #121
    1816 3 blade.
    There 45mm with a 1.6 pitch.
    Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      #122
      Bob took a video with his phone,but hes having problems sending it to my phone as a message or email or something like that. No biggie. Itll run again for all to see.
      Ryan,I know you have Neus in your Maritimo,but you should look into the Arc's. They seem to be bullet proof and make gobs of power.They have a 540XL in a 1680kv and a 540L in a 2000kv.Both would scream on 6s. If I had a slightly longer hull,Id run the 2000kv motors.Plus I can jab a hex driver in an Arc while its running and ruin it and send it back to Arc along with $35,and they ll send a new brand new motor back-no questions asked.
      Oh,and I finally converted the EKOS stingers to 3/16 so I can run man sized props instead of 4mm crap with adapters.Ive also had a few bad wipe outs with this hull and there isnt so much a crack in the gel coat. The polyester resin/fiberglass re-inforcement is working great and it was cheap to do.I can also attribute some of the strength to Great Stuff window and door expanding foam in the bow.This hull is solid as a rock.
        • 9488
        #123
        sounds like these motors work great
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3278
          #124
          If Steve would carry these, the stock quantity would go fast once people experience the power and reliability of them.If I ever need a 540 or 380,Im definitely going with Arcs.
            • 9488
            #125
            The looks of them remind me of the Medusa motors
            and these Arcs sound like they put down some power without wasting amps
            • ray schrauwen
              • 9472
              #126
              They aren't Medusa motors, they are a breed their own.
              I have a pair of those same motors. Damn if I ever get a twin built!!
              i am using them in a 36" China R2 cat.
              To think, I almost sold these motors!! They like voltage and the windings are such thick guage a wire it's silly!
              I better get on my build, just got the mounts from Ben.
              Larry, what are you running? 4S or 5S??
              Nortavlag Bulc
              • ray schrauwen
                • 9472
                #127
                Beijing Electric company motors.....
                Nortavlag Bulc
                • ray schrauwen
                  • 9472
                  #128
                  pdf with specs, 36mm http://www.eletechnic.com/Specificat...36-3021_en.pdf
                  Nortavlag Bulc
                    • 9488
                    #129
                    No one called them Medusa's Ray
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3278
                      #130
                      It's run on 4s. You're missing out Ray. Better get on it. Or just send your build to me and I'll get it done.
                      • ray schrauwen
                        • 9472
                        #131
                        Nortavlag Bulc
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3278
                          #132
                          Eric is going to bring his camera next time so he can post a video for me. Im shooting for 85mph. Hopefully I can get out to run again this weekend.
                          Thanks,Ray,but you really dont need to bow down. Anyone can get the speed Im getting. Its all layed out in this thread.
                          • Skullcracken
                            • May 2010
                            • 617
                            #133
                            Larry,
                            You recommended these before. I haven't put them in yet. What about placing them between the collet and the housing tube? Doesn't placement in the stinger make you have to remove the stingers to grease a flex drive if I use a flex shaft vs wire drive?
                            • LarrysDrifter
                              Big Booty Daddy
                              • May 2010
                              • 3278
                              #134
                              You can put the wheel collars there. I put them as far back as possible in case the wire broke at the collet. Its up to you where you want them, or if you even want to use them. Yes, the stingers need to be removed for grease maintenance, but if you pack it in very well, you dont have to re grease for quit a while. Always worked for me doing it that way.
                              • Livewire121
                                Fast Electric Adict!!
                                • Jul 2012
                                • 317
                                #135
                                Hi Larry,
                                I'm in the process of an EKOS build, so build far I've laid two layers of carbon fiber cloth into the hull. After reading this thread I would like to follow suit in regards to your use of Great Stuff expanding foam and length of your stuffing tubes. My questions for you are;
                                1 How hard was it to reach the tips of the sponsons?
                                2 How far back did you fill?
                                3 Can you provide any pics of your foam setup for visual reference?
                                4 It looks as though you shortened the stuffing tubes in comparison to the EKOS layout, which allows you to seat the motors further towards the rear.
                                What is the length of your stuffing tubes?
                                Thanks
                                Richard
                                HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
