Geico neon yellow - need paint
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7119
    #31
    I am running 7/32 brass w/o teflon... a tad noisier, but as long as you lube often and frequently, no worries. There is lots of debate, which tells me, just make sure your shaft is lubed up and cleaned each time out, us sporters should be fine. Yes, Jerry I agree you want the stuffing tube to go into the nose of the strut - but you can do that also with the teflon if you use it. Heat shrink is key to also reduce water infiltration and drag.
    got vid will post.
    "Look good doin' it"
    See the fleet
    • j.m.
      • Jul 2008
      • 838
      #32
      Originally posted by Jesse J
      ...often and frequently...
      Same thing?
      Long day?
      • H2OCamel
        FAST ELECTRIC EVERYTHING
        • Oct 2007
        • 484
        #33
        looking good Jesse!
        "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
        • Jesse J
          scale FE racer
          • Aug 2008
          • 7119
          #34
          Here is vid, just uploaded
          often and frequently - saying from a good friend and mentor I worked with in Littleton CO
          Yo Camel, got the vegas boxed and shipped? I know you can use the $$$
          See the fleet
          • H2OCamel
            • Oct 2007
            • 484
            #35
            working my * off and now have to work saturday as well...the box is to small for a crush zone so it will be a custom one. hope to get it done this weekend what I have left of one :D
            • Unsullied_Spy
              • Nov 2008
              • 91
              #36
              Got the Bannana boat vid on my memory stick, probably won't be able to give it to you until Tuesday. Looking like I'll be really busy today, tomorrow, and Monday. Did the vid of the cat turn out OK?
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7119
                #37
                yep, its the on i posted 4 posts ago. No rush, got some great pics of yours too.
                gonna taker out again and try out the raised strut. With the new hardware, the strut had to be slotted deeper to allow higher running. Now I have it 1/4-3/16" above base of sponsons.
                Geico stickers are en route
                Thanks ROD!!!
                See the fleet
                • Hydromaniac
                  • Oct 2007
                  • 816
                  #38
                  Thanks ROD!!!
                  You Bet Jesse any time.
                  www.rockymountainthunderboats.org
                  • HYDROJERRY
                    • Jan 2010
                    • 2503
                    #39
                    I went and got both the neon yellow and the neon green,,tryed the yellow on a white bucket then right under it the green,, green to dark and yellow to yellow so tryed misting the green over the yellow and SCORE, thats what i want but how to do it i think ill spray them both into two seperate bottles then mix alittle green into the yellow, thin it just alittle and spray it threw my spray gun,,,maybe!!!Yeah my decals are on there way to cant wait...
                    • Hydromaniac
                      • Oct 2007
                      • 816
                      #40
                      Yes they sure are.
                      • Trea916
                        • May 2010
                        • 70
                        #41
                        genesis geico
                        hey I am getting my stickers from rod too cant wait
                        • Unsullied_Spy
                          • Nov 2008
                          • 91
                          #42
                          Thanks ROD!!!
                          Sweet. A friend of mine wants me to come with him to look at a Jeep on Monday or Tuesday, might have time after that before work to drop off the memory stick. I'd really like to get those pics, too.
                          I'm going to adjust the strut on the Titan to get it riding drier, should I adjust the trim tabs a little as well?
                          • Jesse J
                            scale FE racer
                            • Aug 2008
                            • 7119
                            #43
                            What brand? did you try the Ace brand I posted? it is pretty dang close - then again, I have seen a range of yellow-greens on the real boat as well. Any pics to see the color?
                            See the fleet
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              #44
                              I used the exact ones you showed but havent used it on the hull yet gotta get it right first but haers a pic of what im trying to get close to,,,
                              • dana
                                Banned
                                • Mar 2010
                                • 3573
                                #45
                                indeed. i couldnt find the ace brand so i am using rustoleum flouresant yellow. looks pretty damn close to me
