I am running 7/32 brass w/o teflon... a tad noisier, but as long as you lube often and frequently, no worries. There is lots of debate, which tells me, just make sure your shaft is lubed up and cleaned each time out, us sporters should be fine. Yes, Jerry I agree you want the stuffing tube to go into the nose of the strut - but you can do that also with the teflon if you use it. Heat shrink is key to also reduce water infiltration and drag.
got vid will post.
got vid will post.
