16th. scale Finlay Atlas Van Lines
  • Xfactor
    Banned
    • 861
    You have your motor mounted far foward?I think these smale scale boats run on the edge @ 3s lipo.How many amps do you pull with the X430? Id like to add that I dread scratchbuilding the cowl for this Atlas i really with I had an abs or fiberglass supplier . I need a wirebow foam cutter. I'll probably have to make one; that's usually how things like this go.
    • JimClark
      • 5902
      a block of foam or balsa is really easy to work with
      here is a link to a gallery of build pics plus video of it running
      Billions of happy photos, millions of passionate customers. Gorgeous online photo albums. Protect your priceless memories. Buy beautiful prints & gifts.
      Billy Graham
      • Xfactor
        Banned
        • 861
        Damn your detail is awesome Jim. That turn fin is trick too.Man I like that boat.My hull has been foam filled exactly the same way. I'm just so lasy as far as the cowl goes Jim. I wanna run the freakin thing. All that detail you got in those boats you almost dont want to run them.
        • Xfactor
          Banned
          • 861
          Guess ill do some work on this boat before this thread dies.Tommorrow how about a rudder and some cowl work. Yeah thats what Ill do. Oh sorry Im typing to myself again. Gosh Darnit.
          • HYDROJERRY
            • Jan 2010
            • 2503
            Keep going will be watching,,,,
            • Xfactor
              Banned
              • 861
              Im too cheap to buy aluminum hardware for these small boats so ill make some from brass and silver solder. Here are some plans I sketched out a few min ago.Where does the leading edge of the rudder do best in relationship to the prop. Im assuming the leading edge of the rudder need to start at the trailing edge of the propeller . This facilitates undisturbed water for the prop to eat. Is that right?
              • Xfactor
                Banned
                • 861
                Cowling templates
                • Xfactor
                  Banned
                  • 861
                  #23
                  Jim can a pickle fork sport the same style turfin?If it hit something is it a way for it to break away without tearing out the bottom of the boat?
                  • JimClark
                    • 5902
                    #24
                    Pickelfork turn fins are mounted on the back of the sponson. you can just add an 2/56 nylon screw that can easily break of you hit something
                    Billy Graham
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      #25
                      Dont no about that brass solder thing i have a 24'' rigger and got Hughs strut and rudder to gether, i didnt hit anything on the rudder but cought on my shore string one time just alittle snag and pulled the rudder right off from the solder i resoldered it andit pulled right off with my hand so then i took it with me to work and tack welded it and yes i can weld very good but, the weld didnt take well to the stainless rudder and pulled it right off again now i will just but the store bault stuff... good luck with yours thow..PS nice cowl plans..
                      • Xfactor
                        Banned
                        • 861
                        #26
                        The cowling is starting to take shape. I dont know if I'll fill it with foam and shape,stretch some speaker grill cloth over the framework and brush it with polyester resin,or plank it all the way around and sand it to final shape.It needs to be a hollow cavity so it will drop nicely over the motor;with some room to breathe.Dagg.
                        • Xfactor
                          Banned
                          • 861
                          #27
                          You may notice that theres a piece of wood just inside "YOUR" left sponson that looks like a plank. Yes it is. I don waste materials. I c.a. scrap peices back together to form sheets then cut parts out. Works for me. I keep a big waste basket with scrap balsa,ply,brass tubing,etc.About that hardware;you have to use silver bearing solder or braze and a torch. I have a strut on my 12th scale that runs a 6xl and a 642 no problems.I plan to grind the solder fillets and paint the hardware' so It doesnt look so cheesy.
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            #28
                            Its cool brother i just didnt have good luck with it, ican braze but i think i may just drill a tinny hole and install a bolt in mine, i hear ya about not throwing peices away i have a little box for my left overs never no when you may need a little peice...The cowl looks good, good work,,,
                            • Xfactor
                              Banned
                              • 861
                              #29
                              Heres the rudder post in progress . I drilled the flat piece of brass a little larger than the tube and beveled the edge of the hole with a counter sink bit; so the solder could have a channel to flow into and form a nice fillet around the tube. In the blurry shot im trying to show the solder fillet on the back side that was grounded flush with the brass plate. Im tuggin on it now. It will pull your transom off first.Note the silver ring in the blurry photo around the tube?I cant find my 1/8 inch drill bit. Looks like ill be going to wal-mart tonite.
                              • Xfactor
                                Banned
                                • 861
                                #30
                                Its coming along now.Now I got to cut the rudder out of 1/16 brass plate.Hows it Look?
