traxxas villan build
  • 20psinow
    • Feb 2010
    • 146
    #91
    well started sanding on the transom and its almost done need to finish up the right side on the bottom and epoxy in the center line and smooth it out and ill be ready for the glassing.. gonna put it away for now going out to eat, and i hope to come up with some b-day money so i can order the parts..
    • Make-a-Wake
      FE Rules!
      • 5554
      #92
      Nice Hull work! I notice your power source will be 2 nicads..............you will not be pleased with the performance of a 9XL on 12 nicad cells. That motor can draw 100 amps.......it will suffer. Just as an option.....Have you considered going with a big ol' Graupner 700? Folks have done it with good results. It only draws about 25-30 amps and personal experience with them has shown me they can swing a big prop...........i've ran up to 447's with the 8.4 BB Turbo on 14 cells. Just a thought as an inexpensive option. Keep us up on your build, nice work.
      http://www.offshoreelectrics.com/pro...?prod=grp-6316
      Vid of a Villain with a Graupner 700 (the less powerful 9.6) on 14 cells
      • 20psinow
        • Feb 2010
        • 146
        #93
        well i just got back from my b-day party and came in to some cash, now im thinking about going to a bigger badder setup and run a lipo or some nice ni-cd batterys.. im going to get the hull done (sanding) and lay the glass some time next week and think about what kind of motor would work great, still going to run the 4mm stright shaft and what not but now thinking more speed and power now that i have some money. any thing that you guys think will be a better or greater setup please let me know, just a reminder i dont want a 100mph boat but in the high 30s low 40s will be nice and with a decent run time..
        • j.m.
          • Jul 2008
          • 838
          #94
          Economically, two cheap 2s lipo car packs will do.
          For best sport performance i'd use two big 4s packs in parallel for around 8000-10000Mah total. (LONG runtimes. Great for sport running if you keep temps low)
          Jon
          • 20psinow
            • Feb 2010
            • 146
            #95
            so should i just stick with the motor you put on page 1? i dont know what that motor will handle for volts.. i really want to run the lipos.. why would the boat light on fire with that lipo that i have?
            • j.m.
              • Jul 2008
              • 838
              #96
              The XL motor in that big hull will probably draw around 50 amp continuous.
              • illz302
                Banned
                • Sep 2009
                • 191
                #97
                I have been watching this biting my nails and kicking my self in the arse for ever getting rid of my Villain hell even if i had to replace the motors every 40 runs or so and ran 2x2s it was soo much fun stock!! I cant wait to see this finished. I wanted to do the same thing but run a single vxl waterproof system.
                • 20psinow
                  • Feb 2010
                  • 146
                  #98
                  well thanks man i like to see what others think about what im doing.. i had a post not to long ago that had pics of my old single set up (just a though) was the name of the post but now i wanted to do a full build im gonna try and do it right for my first build i just need to under stand more on the motor and esc im not to great with amps/volts and batterys to stupied to under stand how to mach it all up..
                  • Make-a-Wake
                    FE Rules!
                    • 5554
                    #99
                    I take it you didnt care for my 700 graupner option.............it was just a thought. If you are going to run the 9xl you need lipos for sure. BTW that motor will pull much more than 50 amps.............you need at least a 120a ESC...............I have a 9XL in another boat.........i run it with a turnigy 120a.
                    • j.m.
                      • Jul 2008
                      • 838
                      #100
                      Originally posted by j.m.
                      ...around 50 amp continuous.
                      Not talking about burst currents here. You saw what the power system recommendations were?
                      • 20psinow
                        • Feb 2010
                        • 146
                        #101
                        no i like the 700 graupner idea but if i did that i would like to go to the scale drive.. thats also been on my mind but kinda want something more and like the lipo deal..
                        • 20psinow
                          • Feb 2010
                          • 146
                          #102
                          is the burst crurent is what it would see when you first take off? and as far and the power system recommendations i have never seen them.. is there a link to a page on that?
                          • 20psinow
                            • Feb 2010
                            • 146
                            #103
                            well i pick up some parts to day for the prop and a fue dean leads (male and female) and the precision magnetic balancer looks nice.. i have heard good things about this balancer so well see how it works..
                            • 20psinow
                              • Feb 2010
                              • 146
                              #104
                              well the wood work is almost done!! just need to sand down the epoxy in the center (still needs to cure) and i got to say just to wood in the back of the boat is really strong it will not flex if you put a good amount of pressure on it with your hand.. my guy told me next weekend i can get the glass work done at his house and im going to order more parts.. and maybe start the prop.
                              • j.m.
                                • Jul 2008
                                • 838
                                #105
                                You forgot about the 9XL and 120A esc on 4s LiPo?
                                The wood is looking awesome! Your hull shouldn't have any problems.
                                If you are going to be running a 540XL motor, most people use at least 4mm gold plated bullet connectors, but I guess the deans might work. Be sure to use a small prop to start with.
                                I updated my FECalc with LiPo and Feigao motors. On a Y535 and 4s LiPo with a 9XL, you should be drawing around 50 amps continuous and getting 38mph. This will give you a 5.5 minute runtime with NeuEnergy 4900Mah LiPos. The prop you have, with the 40mm diameter and 1.53" pitch, is looking a bit large for a 9xl on 4s with your hull...
                                You can try it, but work up to it. Don't start with the big one. Absolutely do not run that prop with your NiCds.
                                I'd give this one a shot in 38mm diameter:
                                http://www.offshoreelectrics.com/pro...d=ose-2bld-316
                                Please understand though, IME, FECalc will recommend a prop that is too small for a hull. I went with what was recommended by FECalc on a small 8 cell (GP3300's) mono, and the boat wouldn't even get on plane. I believe a 40mm prop should get your hull on plane, but IDK about going down as far as a 35mm prop... Hopefully we can get someone with more knowledge in here.
                                Jon
