M12 maritimo
  • bonewar
    • Jan 2008
    • 549
    #106
    Resistors
    Received an email from Joe Ford , Castle Creation.
    To solder any thing to the controller voids the warranty.
    Well that's a risk i'm willing to take with this ESC because i will be pushing it to its limits.
    The right size resistor to use is the 1 ohm 5w type as Disar pointed out
    in an early thread.
    He also recommended that i use the same size capacitor that are on the ESC already.
    I will be using the bigger capacitors on this project.
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • Unkle Chopper
      • Aug 2009
      • 38
      #107
      Originally posted by bonewar
      Recived an email from Joe Ford , Castle Creation.
      To solder any thing to the controller voids the waranty.
      They also have a warning in there user manuals that use of timing advance setting 4 "Max power. Most smoke. No warranty"
      It seems like a educated change that has led you to believe that a change in caps is s good idea so like the build pace test the electronic setup slow and steady and hopefully a good result in the end..
      • DISAR
        • Aug 2007
        • 1072
        #108
        Bonewar, which strut and rudder are you going to use? What's the rudder length?
        http://www.rcfastboats.com/
        • bonewar
          • Jan 2008
          • 549
          #109
          Rudder strut
          DISAR,
          The strut i will be using is a Jeff Wohlt special OD 10mm bearings , ID 6mm , stub shaft silver soldered to flex cable.
          With a modified toysports rudder.
          The rudders length is 120mm width 20mm.
          Jeff is making me the strut right now.
          Here are a few pictures of the strut rudder set up.
          The first 2 pic's are the original idea.
          The 3rd pic is the latest idea.
          The strut in the pictures is a speed master strut just to show you my idea.
          More on that soon.
          I've been reading a thread on windscreen shrouds buy Xcesive8 .
          http://forums.offshoreelectrics.com/...ad.php?t=13757
          In the thread it mentions how to make one.
          Well i had a go and it came out real nice.
          Heres where i'm up to.
          Thanks Gerwin for that tip.
          Just the detail i needed for the new hatch shape.
          Bonewar
          • DISAR
            • Aug 2007
            • 1072
            #110
            Nice design
            • Jeff Wohlt
              • Jan 2008
              • 2716
              #111
              Rick, I do not have an order for another strut. Did you want another? Your shafts should be there in the next few days.
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • bonewar
                • Jan 2008
                • 549
                #112
                Canopy Shroud
                Ok,
                I ended up making the shroud out of carbon fiber.
                I used PVA release agent on the hatch and 1 layer of 5oz carbon,
                1 layer of very light glass cloth. Epoxy resin and a days drying.
                Came out real nice. Just the detail i needed for this hatch.
                I've also glass in the tunnel wing assemble on the hull.
                Just waiting on a few more pieces for the rudder strut set up.
                Then i will finish off the back of the boat.
                Heres a picture of the rough layout of the components in the hull.
                Lipo's will go down in the spoonsons.
                Not much room left when ever thing is in the boat.
                Hope she floats!!
                Bonewar
                • tiqueman
                  • Jul 2009
                  • 5669
                  #113
                  Just keeps getting better Rick! I can tell your not enjoying the build at all....
                  • Rumdog
                    • 6453
                    #114
                    Why the strudder? Wouldn't it handle the high speed much better with an offset rudder?
                    • old guy
                      • Nov 2008
                      • 687
                      #115
                      Well I wait for mine to get here I keep reading this Rick and I'm afraid that lay out will not work You will have to go back to the drawing board and start again when you recalculate it again you will see you have not left any room for the fire suppression system looks good and is a very educational thread. Good choice of rudder and strut. But can you build a little faster so we do not have to wait so long for up dates nice work Rick
                      Old Guy the other Rick
                      • bonewar
                        • Jan 2008
                        • 549
                        #116
                        [QUOTE=Rumdog;174357]Why the strudder? Wouldn't it handle the high speed much better with an offset rudder?[/QUOTE
                        Rumdog,
                        I like the inline rudder strut setup better for this project.
                        More of a scale look.
                        Also I'm trying to keep the prop close to the transom .
                        To help with prop torque issues.
                        I have a in line rudder on my Simrad cat and it handles the speed real nice.
                        Oldguy,
                        I'm glad you like my thread.
                        Gee to go back to the drawing board would take me another 4 months .
                        Update at your command !!!
                        OK,
                        This is where I'm up to.
                        I've finished the carbon bulkheads and the structural pieces in the front of the hull.
                        They have all been glass in.
                        I have started to work on the rudder strut setup.
                        Just waiting on a new strut to finish it up.
                        I've finished the detail work for the hatch.
                        The tunnel flap is glass in , just have to glass in the control arm
                        and clear coat the inside of the tunnel wings box to water prof it.
                        Then to the motor mount , drive shaft.
                        Bonewar
                        • old guy
                          • Nov 2008
                          • 687
                          #117
                          I do not see a O ring in there yet
                          Old Guy
                          • j.m.
                            • Jul 2008
                            • 838
                            #118
                            Don't you think that rudder is going to have a lot of drag at 100mph?
                            I'd use a thinner blade and a rooster water pickup.
                            Jon
                            • bonewar
                              • Jan 2008
                              • 549
                              #119
                              J.M.
                              Mate i think the rudder will be fine.
                              If it becomes a problem then i will machine it thiner.
                              What is this rooster water pick up you talk of ?
                              The water intake on the rudder I'm using will be filled in.
                              I am using in hull water pick ups. 1 in each spoonson. 1 for the motor , 1 for the ESC.
                              Got a little done today.
                              Started on the transom mods and reinforcing.
                              Just waiting on my new strut to finish the rear end.
                              Bonewar
                              • j.m.
                                • Jul 2008
                                • 838
                                #120
                                Ooooohh, sorry I forgot about the in hull pickups.
                                I was referring to a rooster tail water pickup.
                                Jon
