M12 maritimo
  • bonewar
    • Jan 2008
    • 549
    #61
    Carbon fiber plate
    I've been busy making some carbon fiber plate (1.5mm thick).
    I will be using the plate for bulk heads and structural pieces inside the front of the hull.
    I also need to make a box type structure for the HV240 to sit in .
    2 make the plate i used epoxy resin , 2 layers of carbon and 1 layer of glass mat.
    PVA plastrene as a release agent on the glass , and as you can see lots of weight.
    The finished part came out real flat and shinny.
    Next update - steering gear -motor mount.
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • ace028
      • Aug 2007
      • 952
      #62
      Sweet!! Watching this one as with the last one lol!
      Twin power =
      • j.m.
        • Jul 2008
        • 838
        #63
        IME you don't usually need a release agent in the glass, but I guess that wasn't a bad idea seeing how smooth the surface came out.
        Looking forward to the speeds this one is going to hit!!!
        Jon
        • DISAR
          • Aug 2007
          • 1072
          #64
          Nice! How did you make the plate, multiple layers of carbon or you put something else between?
          http://www.rcfastboats.com/
          • Jeff Wohlt
            • Jan 2008
            • 2716
            #65
            Just need to wax the glass several times. Wow, that is a bunch of weight!
            www.rcraceboat.com
            [email protected]
            • j.m.
              • Jul 2008
              • 838
              #66
              Bonewar used two layers of carbon and a layer of glass.
              I'm guessing that the carbon was around 5oz/sq yd and the glass was fairly light.
              Jon
              • bonewar
                • Jan 2008
                • 549
                #67
                Jeff,
                I like the PVA because you just have to wash your piece in water to clean up. Leaves a very nice finish. Weight just to make sure it comes out even.
                Disar,
                To make the plate i used 2 layers of 5oz carbon cloth and 1 layer of very light fiberglass. Coat the glass with PVA let dry then add resin 1 layer carbon wet in roll flat add 2nd layer of carbon wet in roll flat add 3rd layer of fiberglass wet in roll flat. put the glass over add weight and let cure for 1 day.
                J.m.
                With the roller i don't use much force. I'm just real gentle with it.Also I like the PVA because of ease of youse.
                Thanks Ace028
                Bonewar
                • DISAR
                  • Aug 2007
                  • 1072
                  #68
                  Thanks. I thought PVA does not leave a shiny surface but yours is beautiful!
                  • bonewar
                    • Jan 2008
                    • 549
                    #69
                    I applied the PVA with a sponge and not a brush , better to spray it on.
                    The end product is very shinny i can see my reflection in it.
                    Bonewar
                    • j.m.
                      • Jul 2008
                      • 838
                      #70
                      A lot of people use PVA in molds for composite sailplane fuselages. Very shiny...
                      • bonewar
                        • Jan 2008
                        • 549
                        #71
                        Hydra hv240 esc
                        This is where i'm up to with the hydra .
                        Trying to work out the best place to put the extra caps.
                        There BIG!!
                        The caps will be soldered in series than join to the ESC wires.
                        I think this will work out OK.
                        Been waiting on my carbon 3mm plate to be cut by the water jet man.
                        His first attempt was very poor.
                        Cost me 1/4 of the plate.
                        Fingers crossed 2nd time lucky.
                        And the hatch ready for primer.
                        Bonewar
                        • bonewar
                          • Jan 2008
                          • 549
                          #72
                          Carbon bulkheards
                          I've started on the bulkheads for the front of the hull.
                          I also made room for the Hydra esc to fit into the space.
                          The front of the spoonsons will get closed cell foam for flotation and strength.
                          When i have done this , than i will glass it all into place ,and put the lid back on .
                          Stronger than the original!!
                          Going to need it with 7+hp.
                          Bonewar
                          • DISAR
                            • Aug 2007
                            • 1072
                            #73
                            Very nice work there! Advanced carbon users only.
                            • Rumdog
                              • 6453
                              #74
                              Are you going to run the 1527 1.5y on 10 and 12s1p? What size prop do you think you'll be spinning?
                              • wolf IV
                                • May 2008
                                • 961
                                #75
                                QUOTE=bonewar;166101]I've started on the bulkheads for the front of the hull.
                                Bonewar [/QUOTE]
                                [ great so far bonewar!! i thought you were gonna keep the weight down on this one
                                http://www.youtube.com/watch?v=e-npTLBHefY
