M12 maritimo
  • j.m.
    • Jul 2008
    • 838
    #136
    Does that fan have anything on the other side? It lookslike it's right up against the CF plate. If so, it'll only heat the boat up more.
    Jon
    • bonewar
      • Jan 2008
      • 549
      #137
      Originally posted by tiqueman
      Looks awesome Rick! Doing the chine like that doesnt cause it to roll in a turn? I know that works on V hulls, just never seen anyone do it on a cat? Did a nice job on it though, as usual.
      Thanks Scott,
      I tryed a small piece of plastic angle glued on the back 2 section of the chime on my Simrad cat and it help it go around corners a little faster , It seamed to stop the slide out affect , Thats until it fell off, glue wouldn't hold it . Didn't show any signs of rolling in the turns.
      So that is why i've decided to do the full chime on the M12 cat fixed solid with car bog and painted.
      Should turn out real nice , Gives the side of the boat a new look also.
      J.M. ,
      The picture is deceiving the fan is about 1" away from the bulk head.
      The M12 cut into the carbon plate allows the air to travel around the bulkhead with the fan in it. Should work ok.
      Bonewar
      SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
      • tiqueman
        • Jul 2009
        • 5669
        #138
        I dont doubt your work at all and figured you had done some type of R&D. It does look really good. Im interested to see it go even more now. Will you please hurry up and finish!
        • bonewar
          • Jan 2008
          • 549
          #139
          Update
          A little more progress.
          I've glassed in the motor mount .
          I checked it into the carbon floor for a real good hold with some clear drying epoxy.
          Then i glass it to the tunnels floor with some very light glass fiber and resin.
          I'll end up sanding it all smooth then it will get a 2 pak clear coat over the tunnels floor and the motor mount.
          Should come out real flat and shinny.
          Another pic of the fan setup for the esc.
          My strut is in the mail.
          Soon as i get it i can finish the back of the cat.
          Bonewar
          • Jeff Wohlt
            • Jan 2008
            • 2716
            #140
            The strut is in the mail on Monday. If you want it extra fast then let me know and we can work out postage.
            I hope this strut is as nice as the rest.....it is big but should fit well. Wish you would get away from those monster bearings and shafts and then we would have more choices! I am also sending the brackets along even though you said you did not need them...you might find that you do.
            Your work is art, man!
            www.rcraceboat.com
            [email protected]
            • Jeff Wohlt
              • Jan 2008
              • 2716
              #141
              His new Strut!
              Lets see if Ricky is sleeping. I get to show his new strut before he does
              It is big and bad.... sporting 10mmx6mm bearings. He drew it up so here it is.
              www.rcraceboat.com
              [email protected]
              • bonewar
                • Jan 2008
                • 549
                #142
                Jeff,
                Just got back from work.
                And yes my friend that looks awesome.
                Send it just as it is mate.
                And thank you Jeff for your help getting this sorted out.
                Bonewar
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  #143
                  Oh that is right...it is day over there when night here. I am headed to bed...1:30 a.m.!
                  Brackets are in there as well. Might need them for another piece of art you do later.
                  It turned out nice. Blade is a bit wider but should be fine...if not dremmel it to how you like.
                  www.rcraceboat.com
                  [email protected]
                  • bonewar
                    • Jan 2008
                    • 549
                    #144
                    Esc update
                    OK,
                    I've finally finished all the solder joins on the esc.
                    I use liquid electrical tape(red,black) to cover the exposed wires.
                    Came out real neat.
                    Couple of pics of the esc motor setup in the cat.
                    Then 7v fan will do a good job of keeping a steady air flow over the esc when running.
                    Should keep it a little cooler.
                    I'm contemplating putting a small fan behind the motor as well.
                    Just haven't got that far yet.
                    8mm shaft , strong!!!
                    Paint this week. Under coat anyway!!
                    I'm a happy man i get my strut soon.
                    Thanks Jeff.
                    Bonewar
                    • DISAR
                      • Aug 2007
                      • 1072
                      #145
                      Very nice job, good idea to place the esc forward, is it going to be accessible afterwards? how will you close that deck area?
                      http://www.rcfastboats.com/
                      • bonewar
                        • Jan 2008
                        • 549
                        #146
                        Thanks DISAR,
                        I'm planning on holding the esc down with some velcro straps glue to the tunnel floor.
                        And leaving the hole area under the front of the deck open.
                        Makes for lots of room for the esc and the cooling fan to do its job.
                        I will be able to get to the esc under the decks roof.
                        The top deck will be fiberglassed back in place very soon.
                        Just have to make up the tie downs for the esc to sit in.
                        Then i will finish the glassing on the front deck.
                        Bonewar
                        • bonewar
                          • Jan 2008
                          • 549
                          #147
                          Update
                          The motor mount is finished.
                          Glassed in to the carbon floor.
                          I've also finished the control arm setup for the tunnel wing.
                          Final coat of resin over the main carbon floor of the cat.
                          Very shinny.
                          Now to under coat !!!
                          Bonewar
                          • bonewar
                            • Jan 2008
                            • 549
                            #148
                            Update water cooling
                            I have been working on the water cooling for the cat.
                            I'm using thin walled aluminum tube to run the water to the esc and the motor.
                            There are 2 water inlets on the cat , i have set they up so that the motor has 1 and the esc has 1.
                            Then they both exit the cat at the back of the spoonsons.
                            Bonewar
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              #149
                              Have you not gotten the strut yet?
                              www.rcraceboat.com
                              [email protected]
                              • bonewar
                                • Jan 2008
                                • 549
                                #150
                                Jeff,
                                No i haven't got the strut .
                                Can't be that far away.
                                I'll check the post office tomorrow.
                                Next update paint.
                                Bonewar
