Hpr06
  • vvviivvv
    • May 2009
    • 1079
    #286
    wish i had bought lehner's, that way i could of copied a set up and used the same volts as them, at the min i can't find any one with the same set up as me thats got it running and got some temp idea's + speeds + amps . everyone on this site is using a diff set up!
    Uk SAW record holder
    • elvish
      • 125
      #287
      Two roads diverged in a wood, and I—
      I took the one less traveled by,
      And that has made all the difference.
      • toysRme
        • Jul 2009
        • 75
        #288
        Dave Im building a twin powered HPR
        Good news....the motors are in and AndyG sent the to me today should have them thursday.
        So now to see how these Hydro/Tunnel mounts fit, they look good, simple and light.
        vvviivvv the good thing about this hull is you can running one of ten setups and still get a very good result, all run 116 kph most run to an average of about 140kph not bad!!
        On with the build!
        STUFF NITRO GO LIPO FASTELECTRICS.COM
        OFF-SHORE-ELECTRICS.COM
        INVENTOR OF LITHIUM CELLS:bowdow
        • toysRme
          • Jul 2009
          • 75
          #289
          Any more progress with the build????im looking for tips on how to put it together.....
          • vvviivvv
            • May 2009
            • 1079
            #290
            It's quite straight forward... Mines about done apart from the bloody antenna
            • elvish
              • 125
              #291
              you could have updated us once in a while...
              shame we didn't see any progress of your build.
              • vvviivvv
                • May 2009
                • 1079
                #292
                Installed the watercooling, rudder last night the drives I uploaded pics of and the mounts I can take pics of, I've been mega busy lately and where in the airport now... My dad is going back to work so the build was fairly rushed in the end
                • vvviivvv
                  • May 2009
                  • 1079
                  #293
                  well tbh got my batts to buy and mount too
                  i have one quick question, i want to run my props inward, the drive line + prop is the port side system is this right? i always snap/unwind shafts because i get this wrong
                  other pic is my watercooling - not bad for a 1st attempt imo.
                  • Anbjorn
                    • Apr 2009
                    • 248
                    #294
                    Wrong prop for that flex.
                    Or more spesific I would say use this flex on the starboard side.
                    Anbjørn
                    • vvviivvv
                      • May 2009
                      • 1079
                      #295
                      thanks.
                      • elvish
                        • 125
                        #296
                        epoxied the carbon plates, drilled the holes, and grinded the epoxy for the bolts to mount.
                        • vvviivvv
                          • May 2009
                          • 1079
                          #297
                          the best investment ever for a 115 builder....
                          i dont know how i would of got 1/2 of the bolts in there without them
                          • justintime2w8
                            • 260
                            #298
                            Yea right, those bolts in the backs of the pillars are crazy tight.
                            www.radtekpowerboats.com
                            • malibu1
                              • Sep 2009
                              • 74
                              #299
                              Gosh you guys are way ahead of me! I have been watching here every day but have not had a chance to get started on mine yet. I have everything for the build now except for the speed controls and some syringes. I think I am getting tired of looking at speed controls. I think I may try the 240HV Hifi's when Steve gets them in. Thought about castles but am scared of them after reading all the posts.
                              • elvish
                                • 125
                                #300
                                installed the first drive today
                                had to drill the hull a little to get it to fit correctly.
                                I filled the dents and hole with black epoxy so you can't really see that its filled.
