Hpr06
  • malibu1
    • Sep 2009
    • 74
    #241
    Elvish,
    I was wondering what water cooling jackets you are going to use on the motors? From the pictures of the mounts you supplied, it looks like you are going to use similar motor water jackets as me.
    Nice mounts on the rear of the motor! I think I may need to do something similar. Do you think the rear mount will make it hard for getting the motor in and out?
    • elvish
      • 125
      #242
      Ok, for the mount, I haven’t done anything yet, have finished the design on paper, I will post it in 10 mins.
      For the water pickups Gerwin, I think we could put one in front of the other.
      On the 3d pictures the motor is a 1521, the coolers are ose coolers for the 1521, all sizes are original.
      • malibu1
        • Sep 2009
        • 74
        #243
        Gerwin,
        I am going to go the home made water pickup route. I have never done it before so I am really scared I am going to messup the bottom of the hull. Your right though, I will have to sand it all anyway. I should put some scratches on the bottom of the hull just so I get over my feers of handling it. I feel like I just got a new car and I am scared to take it out of the garage or get finger prints on it.
        • elvish
          • 125
          #244
          Ok so to understand what I drew.
          Two carbon half mounts, 2.5mm each, epoxy them together, dremel a path in the middle of them right where the motor will rest, and fit a half cut ring from a water cooling jacket
          Second ring to attach the motor to the carbon half mount
          • elvish
            • 125
            #245
            Malibu, there is a way to install the custom water pickup without needing to do any sanding
            But you will need a dremel, 5 min epoxy, tape, and some plastiline.
            step1.
            Take your tubes, fill them with sand, block both wholes, and give them the shape you need. Then cut with a dremel the tube with the angle as shown in the picture in red.
            step2.
            take the pattern of the bottom of the tube you just cut, best to do it on a tape, and stick it on the outside of the hull where you want to install it, be careful, check many times to see if you are where you want.
            step3.
            take the dremel, with a very thin cutter, and start drilling the shape of the tube, better to it smaller than too big, so stop try the tube, and continue. The tube should be able to fit in the hole with little pressure.
            step4.
            Now in the hull, position the tube and fix it with plastiline to a corner leaving the whole area you drilled clear. Put enough so that the tube stays positioned on its own.
            step5.
            Turn the hull upside down, and mask the hole with tape, so that epoxy will not spill.
            Turn the hull to its upright position, take some epoxy, and apply it on the bottom of the tube.
            If you done it right, you should be able to have a clean cut and no sanding needed.
            ps: add a little black paint in your epoxy, so that it matches the carbon fiber and your paint.
            • Himalaya
              • Apr 2009
              • 251
              #246
              This is how I did my pickups. just FYI
              • toysRme
                • Jul 2009
                • 75
                #247
                STUFF NITRO GO LIPO FASTELECTRICS.COM
                OFF-SHORE-ELECTRICS.COM
                INVENTOR OF LITHIUM CELLS:bowdow
                • vvviivvv
                  • May 2009
                  • 1079
                  #248
                  My hpr future looks bad... Might be up for sale soon if my other stuff doesn't go, need the money for a new dh bike
                  That's why progress has halted, have everything now to make the boat run
                  Uk SAW record holder
                  • vvviivvv
                    • May 2009
                    • 1079
                    #249
                    Things looking better, ive sold a few things, got a full size boat with 5 people comming to look at it this weekend if that brings a good price the hpr can stay and ill get my new V10
                    • elvish
                      • 125
                      #250
                      gl selling the boat
                      • elvish
                        • 125
                        #251
                        had some time to play round, and I started designing the back motor support.
                        • tiqueman
                          • Jul 2009
                          • 5669
                          #252
                          Looks good Elvish. What program did you do that on?
                          • elvish
                            • 125
                            #253
                            guys, today I received the motors.
                            they were in customs for a week. Had to go get them myself.
                            As I opened the box, I had a weird surprise am going to share with you.
                            I have sent an email to Steven too, informing him about the matter.
                            one motor is ok, looks brand new. the shaft feel strong, can't turn the shaft easily. Fresh magnet power.
                            The other looks.... used... refurbished... dirty....old...
                            the magnets feel like they have half the strength. and the copper wrapping has 20 % less volume, from the top and the bottom from the other, and the color looks odd....
                            and as last, the cables don't have the same color (the new is red, the old is orange)and one cable has some writing on it.
                            Both motor indicate have been fabricated on the same day.
                            the problem is that am pretty sure they won't have the same Kv (due to the copper wrapping), but before testing the motors (on power analysers), I wanted to get some opinions. and maybe see what is going on.
                            For the price I think I deserve some explanations.
                            if I was going to use them in single power boats, I wouldn't mind. But in the Hpr, I can't risk having this situation.
                            • vvviivvv
                              • May 2009
                              • 1079
                              #254
                              one looks refurbished to me... what winding did you order?
                              • elvish
                                • 125
                                #255
                                yeah I think it is, and I won't accept that. not with the setup I want to run on the hpr 06
                                but I still have to wait for official answers.
                                Am a very easy client, but some things are just unacceptable.
                                PS: i want to say, that it is not Steven's Vaccaro's fault , as he does not make these motors. Just wanted to clear thing up
