It like I had said before; where its made doesnt dictate the quality,the thought put in the design does.
Littlescreamers 63mmwater jacketed Motor
Won't someone by my brand new screamer and motor mount in the FS section???Laser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
Its brand new directly from LS. What do you mean race wind, they only have the 650kv. Let me know what you mean. MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
Theyre under the cooler probably dont go through all that. Ill call castle and ask them. Guess what guys HES HERE! I can tell you guys its a well built motor. I love the way it feels when you turn it. Checked the can for play there was none she was as snug as a bug. I cant wait to get this thing in the boat. Im sealing my atlas on the other thread ,but tommorrow ill be mounting this motor and sealing my circus.Attached FilesComment
Would these motors be suitable for 12 volt systems pushing 4 to 4-1/2in props, 50 to 60lbs scale boats?Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
I think the only drawback would be the amp draw. My monster scale motors (2lbs) draw something like 5-10 amps max. So with these you would have loads more power but you would need something more than gel cells to power them.
I am picturing your 65lb Mr. Darby planing out across the bay:-)Comment
The gel cells I'm planning on using are 50 to 60amp. Also how'd you guess it was a Darby? Also looking to get the Harbor Model Invader Tug.I think the only drawback would be the amp draw. My monster scale motors (2lbs) draw something like 5-10 amps max. So with these you would have loads more power but you would need something more than gel cells to power them.
I am picturing your 65lb Mr. Darby planing out across the bay:-)Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
Thought you guys might like to see this thing mounted in an 1/8th.scale.Here it is in my dumas circusAttached FilesComment
I don't know, big motor, big hull, I am a Darby fan too. That invader tug would be a mean setup too. It would be well suited overpowered.Comment
I was gonna put one in my 1/8th scale Circus build, but it just seemed like a LOT of motor, lol. Looks good, I love that motor mount! MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
My bad, was just responding to your plaintive cry. Not available yet, but if you are current with this thread, the next iteration higher wind ("race")version is in testing and expected soon...
