Littlescreamers 63mmwater jacketed Motor
  • Xfactor
    Banned
    • 861
    #256
    It doesnt work that way. The esc has to be designed around the motor. The companies see whats outthere and build a semi-universal code to run whatevers out there. Thats your different timing setting come from.If someone designs a new motor(little screamers) there may not be a controller to run it properly. That is very possible. I can tell you that theyre telling the truth when they say that.
    • Xfactor
      Banned
      • 861
      #257
      If i were you id do like they say and get a air esc and convert it because the air guys run outrunners and the timings will likely be more compatible.
      • Xfactor
        Banned
        • 861
        #258
        Its really not a major issue. But my heart goes out to you on that blown esc. Man thats a terrible feeling.i hope you get it all worked out. If you decide to sell that 3080 you let me know asap lol?
        • Xfactor
          Banned
          • 861
          #259
          Im anxious as ever to get mine. I can tell you that.
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            #260
            Since people are wondering what props to use here is what I tryed. Prop shop 6516 and 6717. Octura 455, 460, 462, and 465. Prather 250, 260, 265 cut down to a 60. You already know what prop I think works the best out of those.
            Mark
            • Xfactor
              Banned
              • 861
              #261
              Mark please reduce your strut angle and just try a1657 please just try it?Scott just call andy and tell him what you got . Maybe a custom cnc prop is what this bad boy needs> One thing when someone does design a esc around this monster ,its gonna be a bad boy.
              • Xfactor
                Banned
                • 861
                #262
                I know one time yall liked the three blade what ever happened with that?
                • Xfactor
                  Banned
                  • 861
                  #263
                  All we really need is a prop that shines in the 22-24k range that draws around 125 amps I really think thats what she needs.
                  • Xfactor
                    Banned
                    • 861
                    #264
                    Mark you ran a big 465 y ru scared of a 62mmprop with a 1.6 inch pitch?
                    • Xfactor
                      Banned
                      • 861
                      #265
                      Mark please you already got the setup just try it. Ill buy the prop for you and you can have it.You already got a good starting point.Come on man please?
                      • MarkF
                        dinogylipos.com
                        • Mar 2008
                        • 979
                        #266
                        My prop shop props were 3 bladers and so was one of the 460 props I tryed. The motor couldn't pull a 462 with 1.4 pitch. What makes you think it will work any better with a 462 with 1.6. I agree this motor needs to be able to swing a bigger prop and the 1667 would be great if it could. But I can"t make it do what it doesn't want to do. My Neu 2230 can swing a 70mm 4 blade prop but thats not the topic here. I'm curious to see if the swordfish controllers work good or not though.
                        Mark
                        • Xfactor
                          Banned
                          • 861
                          #267
                          Hopefully its just the esc u were using. Forget the cut 1667 for now but u might try the 1657 for a comparison.
                          • K.R.Joye
                            • Feb 2010
                            • 1045
                            #268
                            Were still talking about the 650kv motor right? If racers are having Amp issues now what size ESC are we going to need with the 800kv version, scary........
                            I've had CC 240HVs and have seen the bog factor like Mark stated, same thing with Kontronics HV, they just don't can't cut-it. I've been using Huaya 200HVs(aka Twinkie) great low-cost alternative to the Pop-tart on my HV setups. Controller has been working flawlessly with no bog. I've yet to test my Screamer with the Huaya to busy getting my club boats ready for the new season. Should be ready in June.
                            ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
                            ****2008/9 MMEU LSO, 2008 LSH CHAMP****
                            ~~~~~~~70 MPH Club Member!~~~~~~~~~
                            • MarkF
                              dinogylipos.com
                              • Mar 2008
                              • 979
                              #269
                              Ken, I dont think its an amp draw thing. The batteries and controller are barely warm after 7 laps. Its the controller not sinking up with the motor. I can't believe no one else has run this motor on a different controller except the XPS guys.
                              Mark
                              • Xfactor
                                Banned
                                • 861
                                #270
                                I really think its a fet driver cap issue but why should we fix it? the manufacturers are not gonna pay us. Let them revise their own lame speed controls.
