Cap banks - the pre-emptive answer
This is a sticky topic.
  • drwayne
    • May 2008
    • 2981
    #106
    Hi
    2 ways to set up 12S ..
    either 12S a side..eg 4 x 6S packs
    or 12S shared eg 2 x 6S
    Here's a deck mounted set
    Under the deck I place a piece of nylon cutting board ~10mm thick as support for the plugs.
    I roughen madly before epoxy in place.
    Drill through holes for main plugs + 1/32" for clearance
    Insert presoldered plugs from inside hull, tape over top, invert hull and flood plug area with epoxy.
    Wait 12+ hrs.
    voila'.
    The swordfish 240HV have an on/off switch.
    The above picture show a deck mounted switch to remote this feature.
    use a DPDT micro switch, remember to keep the 2 esc as separate entities at this switch. .
    this diag shows wiring beneath the plug
    . ___
    esc1black---- |0 0| ----esc2black
    esc1 red------|0 0| ----esc2 red
    blank ---------|0 0| -------blank
    • ray schrauwen
      • 9475
      #107
      How do you keep the momentary swich dry?
      Nortavlag Bulc
      • drwayne
        • May 2008
        • 2981
        #108
        I flood with corrosion X before install and they last for ever ...
        • ray schrauwen
          • 9475
          #109
          Very good!
          Did you buy a 250A esc from alibaba? Someone "D. Wayne" bought one pending review. $108 + shipping or slow wait free shipping.
          Nortavlag Bulc
          • justski
            • Sep 2012
            • 230
            #110
            ok new here what are the cap banks for what do they do ?
            • tlandauer
              • 5666
              #111
              You might get a quicker answer by going back to the begining of this thread, I find this thread contains way more than just an answer to a single question.
              Just a suggestion, please don't take it wrong, don't mean to be a smart a**.
              • justski
                • Sep 2012
                • 230
                #112
                no problem ill go back i must of missed something ..thanks
                • drwayne
                  • May 2008
                  • 2981
                  #113
                  Very good!
                  Im either Doc Wayne or Wayne S. !
                  Not D. Wayne, he is probably one of John's kin.
                  W
                  • drwayne
                    • May 2008
                    • 2981
                    #114
                    put your thinking cap on, and read this
                    http://forums.offshoreelectrics.com/...127#post448127
                    • jcald2000
                      • May 2008
                      • 774
                      #115
                      Doc, My cap's are coming in at 160 F (71C), should I add more caps?
                      • drwayne
                        • May 2008
                        • 2981
                        #116
                        They're working hard !
                        What other temps do you have from that run ?
                        motor? leads? batts ?
                        any of those others in poor condition will quickly stress ( overheat ) caps.
                        extra caps may bot solve the complaint
                        Midnight down here in AU. will be back in 8 hrs !
                        • jcald2000
                          • May 2008
                          • 774
                          #117
                          Everything else is below 125F.
                          • drwayne
                            • May 2008
                            • 2981
                            #118
                            Damn !
                            Assuming
                            1. esc is not too small for your setup
                            2. timing is set right
                            and
                            3. motor is not 'free revving without load ' at 100% throttle . ?
                            yes..these caps need support !
                            What qty cells and what esc ? .. to offer some quantification of goodies required .
                            W.
                            • jcald2000
                              • May 2008
                              • 774
                              #119
                              Maybe this will help
                              SF240 and Hyperion or Dinogy 5000's with 1527/1y
                              • drwayne
                                • May 2008
                                • 2981
                                #120
                                [ATTACH=CONFIG]90145[/ATTACH]
                                Wow. 313A max.
                                The caps are hot because the esc is working at 130% its design.
                                I recommend the set as per this link
                                http://forums.offshoreelectrics.com/...942#post447942
                                Use 63V 470uf as per that circuit.
                                make the capbank fit inline between esc and batteries as per this attachment.
                                let me know the next log results.
                                W
