Easy water outlet
  • Jeff Wohlt
    • Jan 2008
    • 2716
    I'm iwth Jim...been using them forever. I have also used them for antenna mounts to slide my tube in. I usually now take a nylon bolt and lathe the hole in the center then bolt thru the hull then run tube thru it.
    I do use shoe-goo on both side to lock it in and seal it.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • questtek
      • May 2009
      • 556
      Great idea...I am now using them for the exhaust cooling fitting on several boats. Antenna idea is also a good one, much easier and less weight that the current brass fittings I am using. Thanks.
      • LiPo Power
        DJI Drone Advanced Pilot
        • May 2009
        • 3186
        Hi
        How do I remove the pin out of my rivet please?
        I was trying but it's sitting inside so tite I will damage it if more force applyed...
        Robert
        Canada
        • topolino
          • Jun 2009
          • 64
          Hello .. take a long rivet and cut the tip with a saw .. not just cut the tip of the pin .. cut a part of the body of the rivet is also
          ... then it is easy to get the pin with a pliers
          pay attention in the first photo of this page where I have 2 rivets in my hand
          My toys
          http://photobucket.com/topolino
          http://photobucket.com/scalecars
          • LiPo Power
            • May 2009
            • 3186
            Hello .. thank you. That was easy...
            Canada
            • crabstick
              • Jul 2008
              • 954
              Originally posted by LiPo Power
              Hi
              Robert
              I just hold the flanged side and tap the pin through with a small hammer
              Matt.
              FE, Nitro and Gas racing in Auckland
              www.rcboats.co.nz
              • LiPo Power
                • May 2009
                • 3186
                I did just that, it works great, thank you. Great idea for water outlet.
                Robert
                Canada
