Blueprinting UL-1 Motor Wires
  • bbill1
    Tunnelboat Mafia Member
    • Feb 2011
    • 123
    #46
    I have been sitting back watching this thread go south all day. Here's my opinion, for what it's worth.
    I see nothing wrong with shrinking the wires to protect them from failure. I see nothing in the rules that state that cheap/poor materials must be allowed to fail. Why say you can change the connectors then have a hard on about shrinking the wires? If I change the connectors does it say how long the shrink must be? Can I re-shrink at all? I thought this was supposed to help the 'newbie' get into the hobby without blowing a ton of cash. Now he has to watch his motor smoke cause someone griped about some shrink?
    Get real.
    Protest me for having shrink on my motor, I'll take my ball and go home and you'll never see me at your pond again. Do it to enough people and you will start to wonder why nobody show's for your races.
    You want to get picky about the rules in Namba? Start calling foul about 'stock' O.S.'s in the stock tunnel class. That'll blow the hair back on a few people.
    Oh, and by the way...
    Not trying to start up the ESC deal again but, If you burned the wires after going to a hotter esc what does that tell ya? Maybe there IS something more to the story than just cost ya think?
    Hmmm....
    Toy frikkin' boats people.
    /B
    Current IMPBA P-O/B Tunnel SAW record holder with avg time of 3.358 seconds @ 67.004 MPH.
    Owner Worlds fastest record setting Lynx with average time of 3.287 seconds @ 68.451 MPH.
    Smocktura Props!
    • egneg
      • 4670
      #47
      Thanks Guys! I was sure this had been addressed and I had read it but couldn't find it. I think this is the crux of the confusion (sounds good doesn't it) the rules are spread all over the place. You would think there would be a way to go back and delete older versions or at least to add an addendum stating that this set of rules was no longer valid and include a link to the latest revisions. I think it would be easy to have these rules added to the IMPBA district 12 website and kept up to date but when I go to the news section the latest news is from 2/27/2010.
      IMPBA 20481S D-12
      • Chilli
        • Jan 2008
        • 3070
        #48
        Okay guys, I'm going to try this one more time. Tony runs record trials where the rules are scrutinized more than heat racing. How serious? In the IMPBA, any internal combustion motor that breaks a record in a stock class gets tech'ed and returned to it's owner as a bag of parts in a zip lock bag. We also take a voltage reading of all FE boats after a record run to verify the boat is within the voltage parameters of the class it is entered in. The intention of my post is to warn Tony of the possibility of his modification being protested, deemed illegal at a trials event and all his efforts going to waste. That's all! Tony gets it so that's cool.
        That being said, I can't imagine anyone having their chops busted for Tony's mod in a club or district race. So go run some boats and have fun!
        Jeeesh.... I'm done with this thread.
        Next time I'll just PM you Tony.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • DPeterson
          • 842
          #49
          bbill1
          I assume this is in response to my post. First of all the Hydra 240 is not a "hotter" esc than a yge 120. My post intent was to explain that (1) when the motors are pushed past their limit it is not only the wires that lead to the windings that short out but the windings themselves suffer greatly. This IMO makes any shrink tube modification useless. (2) I have found repeatidly that the UL1 motors do not like advanced timing. This last occurance was stupid on my part as I did not know the timing on the back up Hydra that I used. It cost me 2 motors before my brain kicked in.
          Like I said I will race anybody, anywhere and with shrink tube anywhere they want to put it. The P-Limited classes have been and will continue to be great for the sport. P-Limited classes for records will continue to create animosity among a small group of RC enthusiast. Good luck with that!
          Staying away from the grey area - Doug
          Doug Peterson
          IMPBA 19993
          www.badgerboaters.com
          • bbill1
            • Feb 2011
            • 123
            #50
            I was actually pointing more to the fact that with adjustable timing etc... , that the newbie could get into more trouble than if he had a plug and play esc like the AQ. And the seasoned racer would try to use it to his advantage (whether that advantage is real or imaginary), bypassing the entire reason the class is called 'limited' in the first place.
            Smocktura Props!
            • properchopper
              • 6968
              #51
              OK, I opened a "can of worms" here without thinking it through, so I'm eatin' worms for dinner tonight.
              A few thoughts/responses :
              #1 : All my P-Ltd records were set with just two motors. Neither of them were "modified". Three records were set with a brand new motor just installed the night before the race which was switched between boats. I did have 5.5's installed with just enough shrink to cover the bullets. The tunnel record was set with an older motor, un "shrink-modified" It burned the stator a few weeks later.
              #2 : Upon current re-thinking, I believe the rule ( to paraphrase) "motors must be run as shipped from the manufacturer" denies the shrink-mod. I'll act accordingly.
              #3 : I've been competing in spec from the very start. Lots of heats. I lunched two motors in all that time, one from a burnt stator and one from a cracked rotor, never from melted wire insulation.
              #4 : I think the stock UL-1 SC is a great choice. I have tried pushing the timing with other SC's and it eats motors. ( see #3 above)
              #4 : Spec racing, as it exists today is not exactly "entry level". Competitive boats are rarely the rtr's that would ease new blood into the racing game as was initially envisioned. Stock rtr classes or classes like the IROC Vac-U-Pickles can still offer this. There's been many SV-27 only races that were successfull. I'd buy a rtr immediately if there was a "one design class" and have more racing fun, which is what I'm all about.
              #5 : Doug P has impeccably prepared boats and is a top driver. Therefore when I compete with him he must wear a blindfold.
              Thanks to everyone here for sharing their thoughts. There's something that I've been working on that's sat in my kitchen now for ten days that needs to be mated with something in my garage so I'll see Ya' soon .
              Tony/Properchopper
              p.s. : The worms were rather tasty when served with flava beans and a mild Chianti.
              • longballlumber
                • 3132
                #52
                Tony/Properchopper
                I would support this idea of spec/IROC racing type of mentality 100%!!!! Same hull, same motor, same controller, and same prop. Sign me up. I feel this will also teach new racers what makes a boat better/faster rather than throwing a new motor and increasing the voltage... Just my $.02
                At any rate, this is a GREAT comment Tony!
                Later,
                Mike Ball
                • G-UNIT
                  • 949
                  #53
                  Sorry I must be alittle off here on this but what is ment by blue printing, it just documenting what mods you did?
                  I thought blueprinting was actually drawing a blue print with demensions and specs ect ect...
                  please fill me in so I don't sound stupid when talking about this, THANKS.
                  G.
                  • properchopper
                    • 6968
                    #54
                    G.
                    The term 'blueprinting" as used here is a colloquial term referring to, in the literal sense, adjusting/returning an item to it's intended design specifications often illustrated by a blueprint as you described. Mass produced items often stray from these specifications as machining/production tolerances change over time. My use of the term blueprinting is technically incorrect - my bad - I could have used a better word to describe what I did.
                    • G-UNIT
                      • 949
                      #55
                      I asked this question just alittle while ago but I don't see it now so i'll ask again.
                      What do you mean by blueprinting, I alway thought it was actually drawing a blueprint with demensinns ect..
                      or in the rc world is it just documenting mods.
                      • properchopper
                        • 6968
                        #56
                        Later,
                        Mike Ball
                        Mike there's an ENORMOUS amount of wisdom in that one simple statement. Rather than joining the ZSP/WTS? club {ZoomSplashPlop/What'sThatSmell?}, learning the art of fine tuning a boat to go six laps on the 1/6 mile would definitely create much more all-around satisfaction with our "thing" in the long run. And as long as I'm on the soapbox, I'll say that the recent proliferation of decent (but mildly tuned) rtr's is a double edged sword : It certainly allows beginning boaters to painlessly avail themselves to the fray, but prevents in some way learning the skills in scratch building or rigging and tuning a bare hull. I guess it's all good. But heck yeah, I'd love to compete in a "stock rtr" class. There's certainly a good selection of these boats now being offered. Imagine six MC's, Stillettos, or Impulses battling it out on the course. Yum !!
                        • ray schrauwen
                          • 9471
                          #57
                          Later,
                          Mike Ball
                          I have been chomping at the bit to get IROC style racing up here in our club but, they whine, & whine...
                          Nortavlag Bulc
                          • Doby
                            KANADA RULES!
                            • 7280
                            #58
                            Really??
                            Grand River Marine Modellers
                            • Doug Smock
                              Moderator
                              • 5272
                              #59
                              We all run the same equipment in every FE class in Atl. The hulls vary in some classes but the motors, ESCs, and even props are the same for the most part.
                              We all agreed to keep it this way. It keeps the racing tight and the wallet in your back pocket where it belongs.
                              It works for us.
                              Doug
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
                              • ray schrauwen
                                • 9471
                                #60
                                Originally posted by Doby
                                Really??
                                Where have you been? I've been trying to run a class with spec'd props, motors etc forever! Everyone groaned, plastic props, UUUUGH!!
                                Graupner makes CARBON props that run very well on spec motors. You know, you use them all the time.
                                Maybe with some older blood out of the clubs here we can get such a class.
                                I have a boat ready for such a class.
                                Nortavlag Bulc
