Ok,
Now onto the fins and wings... this is bit involved, they will be attached to the stock mounting tabs which are very clever, using 3mm blind nuts and nylon bolts. I used carbon fiber here again to stiffen and add strength. 4mm carbon tubes add further bracing attached with BVM epoxy.This is superior epoxy I used in all my builds.
You can see here in the last photo the little 1mm thick carbon squares, this is used to bolster the mounting bolt area to prevent the glass from ripping out in a blow-over. Also, scale spacing is used to space the fins off the deck, they dont touch here about a 3/16 gap is used.
Important: a slight extra gap is used just about everywhere since this model will be painted with 3 part system using clear coat, so the extra space will be needed.
Also in photo 2, you can see the 2mm thick carbon band added to mounting tab for blind nuts.
