Okay, so I just got done installing the strut assembly! I put almost as far forward as it can go. Its kind of odd, the screws that were included with the strut have some strange sized allen key head.... I have both metric and standard allen key sets because I had come across a similar problem before in the past, in yet I couldnt find anything to fit snugly enough to simply tighten the bolt and nut together! So I ended up using some different bolts and nuts, they are M4 sized which I really like and use all the time in all sorts of things, but I noticed they are a teeny weeny tiny little bit smaller than the normal included screws.... I still need to sand down the inside of the strut in order for the 5/16 tubing to fit in snugly. I havnt found any adhesive sandpaper though, I might just superglue some to a drill bit if worse comes to worse. I have to go to work in a few hours, but im going to have a good amount of stuff curing while im away, then when I get home tonight I should be able to cut the hole for the 11/32 stuffing tube and have the cowling and cockpit epoxied together. Theres only 1 pinhole I noticed on the cowling, and the cockpit is good, so im just going to cut out the windshield and then it should be good for cleaning and sanding. Im just going to have the saltwater scoop cut out in the front and leave the normal cowling the way it is for now.
